Question about Toshiba E-Studio 3511 Color Copier
Coming up inner tray full
Cant seem to fix, turn off at powerpoint turn back on keeps doing same, copying of A3 paper
Technican came in
Posted on Mar 05, 2009
How do I get a Blow up (say 150%) PDF snapshot view of an image to print from A3 not A4 print tray
Hi Paul,
I would try and insert the PDF as an image to Powerpoint, crop the image to your desired proportions, scale it up to your preference, then print the Powerpoint slide on A3. Alternately, print the slide to PDF, then print.
Good luck
Feb 22, 2015 | Office Equipment & Supplies
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Jan 19, 2011 | Office Equipment & Supplies
How to copy a3 to a3
simply place the original A3 size paper on the glass, now select the tray which have A3 size paper in it, now press the "start" key. you will get A3 to A3 copy....
Feb 18, 2010 | Konica Minolta bizhub C250 All-In-One...
How do i copy an A3 to A3 paper
put a3 paper in the paper tray and adjust paper size wheel on trays righthand side so it says A3 doh.....................................
Jul 08, 2009 | Ricoh Aficio 2015 Copier
How to reset the settings
Use the bypass tray for A3 or any tray which can also be adjusted to take A3.To adjust the tray, extend the green lever to the place indicated as A3 on the tray then load paper and on the control panel or key panel , press the paper key and hold until it blinks while the rest is off, use the paper select key to adjust to A3 and press print key, then press the paper key again.
Apr 21, 2009 | Sharp AR-5320 Black and White Copier
Error 270940 for Estudio 350
The A3 paper will not pass through the copier when the cassete is full. Copier states "Add Paper". When you push the A3 tray in you can hear a winding sound and then when you startt to copy it asks you to add paper.
Apr 16, 2009 | Toshiba e-Studio 350 Copier
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Feb 19, 2009 | Canon iR 2016i Black and White Copier
How to set the paper size in the trays?
most are set by the trays itself, when you adjust the "guides" that go against the paper it adjust some levers on the side or back of the tray which push on some sensors behind the tray.
Some however you need to turn a dial in the tray to the paper size you need.
make sure the guides are snug against the paper, the dial or settings are correct and that there is no paper behind the tray.
Also I'm not sure what country you are from but in the US we do not use A4
Nov 23, 2008 | Panasonic Workio DP-2500E Copier
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Oct 02, 2007 | Sharp AR-161 Laser Printer
Toshiba E-Studio 3511 Color Copier Logo
509 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
