Question about Denon AVR-2801 Receiver
How do i connect my denon RC7000CI to denon amp. 2801
I dont know hot to connect my denon EC7000CI receiver unit to my amp. DENON 2801
I cannot access the setup menu on the unit display or via the s-video monitor out -- everything was working fine a few days ago. I have reset micro, unplugged all night, reset again, and still cannot get to the menu in order to correct connections, esp for digital. My problem is on the avr5600 but seems like this happens on many of the denon units
Posted on May 29, 2010
I have an old Denon stereo receiver DRA - 565 RD. Do you know how I can connect my iPhone to the receiver to play music from my iPhone?
You need a 3,5mm male stereo connector to RCA male jacks (see attached image). Plug the 3.5mm jack to your iPhone and the RCA jacks (red & white or red & black) to your Denon Receiver's CD in or Tape 1 or 2 PB (at the rear of the unit). Then select the input where you plugged the RCA to (front of receiver: CD / Tape-2 / Tape-1). Hope this will help. 25303676-z0ul41frrnrex4ege2epffps-1-0.jpg
Dec 02, 2014 | Denon Audio Players & Recorders
I have a Denon AVR-2801. I use an optical cable from the TV for Audio Out to the receiver. I set the receiver to TV/DBS but when it comes on, it just says TV and I get no sound from the receiver to
You need to do the input assign. The receiver doesn't yet know that you plugged a cable in to one of the Optical ports.
If you have done the above, then the next thing is to check the amp's Mode button. This cycles the input between Optical and analogue audio inputs.
Sep 05, 2014 | Denon AVR-2801 Receiver
I need help configuring my denon avr 2801 receiver, im trying to hook it up to my tv for surround sound
Just moved and got mine hooked up last week. Was working great and now I can't get anything. The reassuring "click" I've always heard when I switch between inputs is gone. Anyway enough about my issue, what specifically are you having trouble with?
Sep 06, 2010 | Denon AVR-2801 Receiver
Denon av receiver switches off
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Feb 19, 2009 | Denon AVR-2801 Receiver
Video performance question
The 2801 (I used to have a 2803) is just an AV receiver, so it doesn't do any video processing.
If you get a DVD player with HDMI or DVI output, you'll be better off doing what you said - bypass the receiver for video and connecting the video directly to your TV, and the audio to your receiver.
It makes things less convenient since you can't switch inputs only with the receiver's remote, but you'll get a much better picture.
If you really need to control the whole system with a single remote, consider getting a Logitech Harmony remote or something similar. They're very convenient.
Apr 05, 2008 | Denon AVR-2801 Receiver
Picutre but no sound
audio will not run through an s-video cable.   it is only for video.  you will have to still connect normal cables (red/white) to get sound.
Dec 29, 2007 | Denon AVR-2801 Receiver
The System Set up Menu does not display to my monitor.
The Denon AVR-2801 receiver outputs the "on-screen" menu and interface with priority to the S-VIDEO output of the unit.
If you have any S-VIDEO cables plugged in, you will need to navigate to the appropriate S-VIDEO input on your television/monitor to be able to see the on-screen menus.
If you need additional help, please feel free to leave a message here and here is a link to the manual that explains the menu and on-screen functions in more depth. Especially see the "notes" section on page 14. I have had several of these Denon amps and the only input I could get the "on-screen" menu was the S-VIDEO MONITOR input.
http://oldusa.denon.com/catalog/pdfs/AVR2801DFU.pdf
Nov 16, 2007 | Denon AVR-2801 Receiver
Denon AVR-2801 Receiver Logo
193 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
