Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Threw wii remote into tv
Whered do i find replacement screens without spending 500$ to 700$ like they are trying to charge me. i can put the clear screen and the next one behind it in myself but they want to charge me 250$ for shipping for the parts
I have screen if you want i can sell to you.
where you lived?
thank you
Posted on Mar 05, 2009
Smartphone how can i replace screen protector without air bubbles like Pro does ?
Before putting the new protector on the screen must be completely clear of any dust/dirt. I use an alcohol wipe first to clean the screen then a clean microfibre cloth to dry the screen and wipe away any remaining small dust particles, then slowly apply the new screen protector like in the video above
Apr 16, 2014 | Apple iPhone Smartphone
My Samsung galaxy s3 charging port is broken, my screen is also cracked. Will i have to get my screen fixed in order to get my charging port fixed?
No, charging port can be repaired without having the screen replaced, you might want to consider this though, since they are already in there fixing the power connector they might as well fix the screen and save you the disassembley charge next time. Up to you though
Mar 17, 2014 | Samsung Metallic Gray Galaxy Note 10.1in...
The interior fan will not work and consequently it is a problem on winter mornings to clear the screen. I have taken the fan off and tested it and it works fine. I have also replaced the switch panel on...
if you have power to the motor then its obvious that power goes to the fan motor then back to the switch which then passes the current to the reostat which then is earthed ,so the reostat is the end part of the circuit ,where ever this component is situated .I would imagine that the reostat is the problem ,a quick solution would be to find the feed to the motor then earth the other side at least this will allow the fan to work in the short term ,if you can find a older car where the reostat is a shunt coil the you could rewire it so it only had 2 speeds fast and half speed without spending a lot of money as some of these reostats can be expensive as they are dealer only parts
Nov 02, 2010 | Mazda MX-5 Miata Cars & Trucks
Hello, when I put a game in the screen says, open
Clear the system cache:
1. On the console, go to My Xbox, and then select System Settings.
2. Select Memory.
3. Highlight any storage device, and then press Y on your controller.
4. Select Clear System Cache. If Clear System Cache is not available, use the following controller button sequence to clear the system cache: X, X, left bumper,right bumper, X, X Note If you don't see a system maintenance prompt on the screen, try pressing the button sequence again.
Try playing discs without the hard drive in:
1. Turn off your console.
2. Locate the hard drive on your console.
Press the release button on the hard drive and lift the hard drive from the console.
Turn on your console.
3. Try to play a game disc.
If this resolves the problem, you will need to replace the hard drive.If not, do the same thing for your memory units. If it works without them, the they may be bad.
May 12, 2010 | Microsoft Xbox 360 Console
Ds problem
Oh dear, sounds like someone has replaced the bottom screen in the past with a none genuine DS screen that has no insulator on the back.
There is a very good chance the motherboard is toast now, to use a technical term, but there are some small chances here.
If the insulator is there, its like a black tape on the back of the screen, put some more tape where you see the burn marks. Put it together try it. next make sure the top and bottom screen ribbons are good and i mean no nicks or heavy dents. If you find one replace it, also make sure they are plugged in properly. Sometime the look like they are but are actually not.
Lastly you could try replacing L2, the small rectangular thing next to the power switch.
All I can say is good luck.
Jul 02, 2009 | Nintendo DS Lite Console
I have a ge 52'" hdtv rear projection that is blurry
sorry about that sometimes theres no easy fix... it would sound like to me it posssibly a alignment issue....unfortunally this means the set need a manual service alignment...techs like me use a special mode that we go into that we manually align the points on the screen. the center of the screen being clear is a good thing it means you probally dont need the cost of the parts or cuicit boards. its software not hardware. Tech can spend a great deal of time on the alignment. and this is where the cost is. I charge no more than 100 dollars at my shop for ths but as you can imagine it vares from shop to shop.
Apr 04, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Palm m130 display screen will not display after replacing battery
have you fully charged the battery?
Have you tried a reset and a hard reset?
hard reset, push the power button and the reset button at the same time. (All data will be cleared)
Hope this helps.
Ed
Jan 10, 2009 | Palm m130 Handheld
Please help!
If the screen is clear that may work. but if its tinted you wont be able to see the image clearly without the tinted rough screen .But if its clear you should be ok, however the other screen will get broken super easy without the protective scren protecting it. New screens are exspsensive. The following link should have your screen.
http://servicemanuals.vstore.ca/
Jul 26, 2008 | Philips 51PW9303 51" Rear Projection...
Ti 83 black screen problem
i had the same problem. If you hit 2nd down 2nd down 2nd down and keep repeating untill the screen clears it should solve the problem. i tried the other solutions that tried clearing the memory and they didnt do anything but erase the equations i had previously put in it (great). But this should work.
Feb 22, 2008 | Texas Instruments TI-83 Plus Calculator
Does any one know how to replace the screen from an iphone?
Yes, you can buy a replacement screen. However, they are sold out at the moment. You can buy one at
 http://www.gethightech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=IP-2085&Category_Code=IPHONE
Jan 10, 2008 | Apple iPhone Smartphone
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
