Question about Sharp AR 163 Copier
What is the meaning of f 5 error code in sharp AR163 PHOTOCOPIER
ERROR CODE F5 FLASHES AFTER START UP
  • Anonymous Apr 06, 2009
    I have the same poblem, I have tried to all solutions but my problem still fix.
  • 37 Answers
F5 is exposure lamp problem, to fix this problem try these solutions:
Solution1: switch off and on the machine.
But if this is not working try solution2
Solution2: Step1: Press continuously Clear key then Interrupt key then Zero key then Interrupt key
Step2: You are inside the simulation if the display turns off but if not do again step1.
Step3: Press 14 then press print button
Step4: If not canceled try step1 to step2 again then press 16 then press print button
But if this is not working try solution3
Solution3: try to open the platen glass and clean the mirrors and also the bottom side of the platen glass especially the white correction plate then apply solution2.
Posted on Mar 03, 2009
Our copier just started flashing F5 on it's screen. I looked in the manual and it has nothing about an F5 error. Is there anything I could do to clear the error and get it going again?
Hello
The error that you see has got to do with the copy lamp.
Either the control ciruit (inverter) or the the lamp is open circuit
Regards
Apr 28, 2011 | Sharp AL-1642CS Copier
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
F5 Error flashing
Hello sir; The F-5 means the exposure lamp bad, replace it, will take care your problem.
Apr 24, 2009 | Sharp AL-1642CS Copier
SHARP AR163 Displaying H2 error code
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
TROUBLE SHOOTING SHARP COPIER CODE F 5
i have problem in Sharp AR 200,and i dont know haw to fix,error code F5
Jan 21, 2008 | Sharp AR-160 Copier
419 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
