Question about Intel D845GVSR Motherboard
No sound from the speakers
I cannot hear any sounds from the System speakers.checked speakers and the jack found to be ok but suddenly this happened.I need the appropriate Audio Driver Thank you.
  • 1,223 Answers
Pls update ur driver from here*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
pls rate me FIXYA if i have fixed ur problem
Posted on Mar 03, 2009
Suddenly no sound from speakers
First, we must determine if the problem is with the speakers themselves, or with hardware or software of the computer. Try plugging a set of headphones into the audio out jack of your system (often times, this will be a green colored jack). Play sound on the computer while listening to the headphones, can you hear the sound? If so, the problem is with the speakers, otherwise, you need to troubleshoot software/hardware of the system. Another method would be to try plugging these speakers into the headphone jack on an mp3 player, mobile cd player, stereo, or similar device. Aside from the system not putting out sound, the speakers could be plugged into the incorrect jack on the system (not audio out, OR not audio out on the correct device), or turned all the way down.
Sep 18, 2011 | Dell A215 Computer Speakers
I have a 1993 Toshiba 32 inch tv. suddenly there is no sound. The mute is NOT turned on. What might be the problem?
Hi kohn,
Plug your headset to the earphone jack (if installed) of the TV.
If you can hear the sound there, the fault may due to open(defective) internal speakers or the earphone jack itself. Faulty internal speaker may replaced with new sets to back your sound to normal again. If the earphone jack was faulty, you may spray it first with electrical contact cleanerwhile inserting and pulling the headset plug into it for one minute to clean the contact. If nothing happens, this jack need to replaced with new one.
If you can't hear the sound after inserting your headset, this is an indication that the audio circuitry was gone bad. The most common caused of this trouble was the faulty sound IC(mounted in heatsink). This is the one converts the audio signal to sound and feed to your speaker's. I would advice you to look for a qualified technician to check this parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 13, 2011 | Toshiba Televison & Video
I can hear the sound in headphone but built in speaker are not working. what to do
Hi, Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • OR
  • If the connection ok increase your volume and open the cable from the pc.
    Now you will touch the stereo jack, can you can listen a sound when touch the jack. If you will not get any sound, think there is the problem in your amplifier or audio system has not any voltage. To confirm the voltage check by multi miter or can go any local Technician .If the voltage is ok, think your sound system defected and should go to Technician.
  • If your sound system is ok
  • Speaker Cable connect to an audio port (Audio/Video port in system box).
Hope this helps ,
May 17, 2011 | Acer Extensa 5620-4020 Notebook
I can not hear sound what problem of this?
Several things must be in place to hear sounds on your pc.
You must have speakers - the kind you not only plug into your pc but you must also plug them into your wall to have a louder sound. OR --- you can use head phones. The headphones plug into your pc sound card.
You must have a sound card or onboard sound
You must have a sound card DRIVER.
These three things and some reading will get you going
Best of it
Rice @ Fix Ya
Dec 14, 2010 | Computers & Internet
My One Speaker is sounding
If the driver is updated, and the speaker balance is correct, true to move the jack, insert and remove it, while playing sound, see what happens.
It could be a wiring problem.
Did the sound suddenly go or it happened after something specific?
Have a great day.
Mar 18, 2009 | Intel DG31PR Motherboard
Both speakers have sound, but some of it will not play.
You have connector problems- probably bad/bent/worn "jacks" in the speakers or they may be dirty (oxidation, etc) or fatigued. If you can get to the Jack on the inside of the speaker make sure it is making good contact with the plug. Clean the surfaces using alcohol on a Q tip or cloth. Many of these type speakers are not serviceable.
Mar 08, 2009 | JBL CREATURE II Computer Speakers
No sound in my PC
Are you sure you have not done the volume mute.
Check for the speaker cable if the pin is correctly inserted in the speaker jack.
or try the method which is always handy . Go to Start + Programs + Accerories + System Tools + select System Restore , Remember you last heard the sound and restore .
Dec 15, 2008 | HP Officejet 4355 All-In-One InkJet...
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
No sound
Some TomToms ( especialy early ones ) are reported to have faulty speakers. Its most likely this is the fault on yours. Another problem particular to TomTom one is the external speaker jack on the base of the TomTom. Thsi jack socket also acts as a switch to turn off the internal speaker when and external one is used. When a plug is inserted it opens 2 contacts and they colse again after any plug is removed. If these contacts have remained open or been bent or become dirty this will cause no sound out of the internal speaker. However , there are routes the TomTom circuit uses to get sound to the speaker. One is direct ...... This is how you hear the TomTom Drums sound ...and the other is for 'most' other sounds , via the external speaker jack.
This gives us a possible check on any report of faulty sound as follows.
If you hear the TomTom drums OK , then this proves the speaker is OK too. BUT , if you hear no further sounds after the TomTom drums then it will be almost certainly be the speaker jack socket thats at fault.
Good luck
Jul 11, 2008 | Tomtom ONE GPS Receiver
No sound through speakers, but ok through headset
u have a problem either on the speaker or on the sound amplifying circuit. signal coming from the earphone jack is not amplified. check the speaker first. if its ok then check the audio output ic(integrated circuit). good luck!
Jan 31, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
