Question about Toshiba Satellite A205-S4707 Notebook
Toshiba Satellite A205-S4707 ethernet connection issues
My Toshiba Satellite A205-S4707 is having internet connection problems when I try using an ethernet cable, and atm all i can use is ethernet. it says i have internet but when I try getting on the page is just blank and it says at the bottom ''Website found. waiting for reply.'' and it never connects... and i'm musing vista if that effects the solution...can anyone help?
  • 5 more comments
  • Chelsi Mar 03, 2009
    I'm using Cable, connected directly to the modem and atm the only firewall I have is windows firewall and it isn't blocking access.
    Rebooting everything had no effect on the connection.
    This happened when I first got the laptop, and since I just reformatted it, I think it is a reoccuring issue with the out-of-the-box state of my laptop.
    To fix it last time, a tech went into the CMD and typed some stuff in, but I'm not sure what he typed in. After he did that, Ethernet worked normally until I had to recover my system.
    for some reason it still won't allow me on. It came up with 0% loss. It pinged just fine and everything came back how it should have but the internet still just stays blank and stays "connecting"
  • Chelsi Mar 04, 2009
    ya i'm using another pc to get to this site in hopes of finding a fix
    well... that didn't work either and I think I do have to type something into the CMD because that is how i remember them fixing it the first time.
    *sighs* this is actually making me a little sad now... that still didn't help. the worst part it i know it isn't the ethernet port, cable, router, or cable provider... i know it's something in the programs somewhere causing it.
    the laptop will even start downloading vista updates when connected. i just can't browse the net or play any mmos, it just keeps telling me it's connecting and waiting for a reply.
    thanks for trying and making so many suggestions
  • Steve Bumblis May 11, 2010
    Are you using cable or DSL?
    Do you connect directly to the Cable/DSL modem or do you have a router in between?
    In any case, power all off , ie modem , router if you have it and the pc.
    Power up modem first, give it a full minute to boot, then same with router if applicable, then PC , and try again.
    Also verify your Antivirus firewall isnt blocking access. Sometimes you have to tell it explicitly what type of connection you are using.
    Scholar:
  • 82 Answers
Try this:
Open a command prompt. If it has been opened before you should see it on your start menu. If so , RIGHT click on it and select Run as Administrator.
If it is not directly on your start menu , go to Start > All Programs > Accessories > command prompt and do the same.
In the command prompt , type "ipconfg /release"
without the quotes of course.
Then type in "ipconfig /renew"
You should have an IP Address now.
Type "ping www.google.com"
you should get something like this:
Pinging www.l.google.com [64.233.169.104] with 32 bytes of data:
Reply from 64.233.169.104: bytes=32 time=15ms TTL=247
Reply from 64.233.169.104: bytes=32 time=14ms TTL=247
Ping statistics for 64.233.169.104:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 15ms, Average = 14ms
You should have 0% loss. If not , something else is going on.
Otherwise , try your browser now and you should be able to connect.
Posted on Mar 03, 2009
  • 1 more comment
  • Steve Bumblis Mar 03, 2009
    I assume you are using Internet Explorer.
    If so , close it , then go to Start > Control Panel > Network and Internet.
    Under internet options click on Change your hompage.
    On the top of the new window will be several tabs , go to the one on the far right , Advanced. Go to the bottom right and hit reset.
    Try it again.
    Are you using another PC to get to this site?
    If so , try downloading Firefox and see if you have the same issue.
    http://www.mozilla.com/en-US/firefox/
  • Steve Bumblis Mar 04, 2009
    Ok , go back into the administrator command prompt.
    Type "netsh winsock reset"
    Then type "netsh int ip reset"
    reboot and try again.
    Yeah , thats kind of depressing.
    At this point, if it was an XP box I have a way of actually uninstalling TCPIP , that almost always fixes issues like these, but Vista doesnt allow that.
    Only thing I could suggest at this point would be to rule out an OS issue, boot off a LiveCD like Knoppix. Just google it , burn it to a CD or DVD and boot off it. If it can get on , you know its an OS issue.
    If not. Then the router doesnt like your NIC or some aspect of it.
    I have seen rare occasions with some modem/router combos that some MAC addressess are not liked for some reason.
    You can clone the MAC from your other PC by doing ipconfig /all
    and noting the hardware address it should be something like 00-FF-17-4D-FD-84
    Take that to your vista box go to control panel Network and sharing > view status > properties > configure > advanced and find a value in the list that says locally administered address or harware address and put in the value from the other PC without the dashes.
    You will want to make sure the other pc is not connected to the network at that time as the router will think the laptop is the other PC and give it the IP that the other PC uses .
    Also a pcmcia or USB NIC might be in order.
    After that , I dont know , good luck.
How to fix TBX Error on Toshiba Satellite a205-s4707
Take out battery from it, and re-insert it after 15 minutes or so. This must make it a hard reset. If it too doesn't help you, make sure there is a software corruption has been occurred. Re-install the O/S is the only solution. Electro help
Jun 06, 2014 | Toshiba Satellite A205-S4707
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
Toshiba Satellite A205-S4707 Boot time is to long need help
you may need a fresh install of the OS, maybe upgrade the ram to 2-3gb, or the worst case factory discs for series model laptop.
Oct 19, 2012 | Toshiba Satellite A205-S4707 Notebook
Hello all! I have Toshiba Satellite a205 s4707, with Windows 7. It has latest Toshiba drivers, bios is after update, but I can't run camera. I tried everything that I found on the internet but non...
Go to toshiba.com and download the correct drivers plus the updates. Any other problems use the phone number on the web site for technical assistance.
Toshiba have got it right.
Jan 17, 2011 | Toshiba Satellite A205-S4707 Notebook
My staellite A205-S4707 gets a charge, powers on but will not stay on for more than 30 seconds. any thoughts here?
A couple of thoughts,
Is this the case while connected to the charger? If not try starting it while still connected to the charger. If it runs OK, your battery may have died.
If it still doesn't run, it may be a over-heating problem. Check underneath, see if all the vents are clear and free of dust.
Mar 23, 2010 | Toshiba Satellite A205-S4707 Notebook
On my Toshiba Satellite a205-s4707 dvd player not working
Allright this one can be tricky so we need to isolate the problem between software and hardware.
First, get into the bios and see it's being detected.
If not then turn off the computer and unscrew the drive from the laptop, MAJORITY of laptops only need to have one screw unscrewed to release the drive. If yours doesn't then you'll have to do a little more work, let's just assume you have the majority for now.
Next, pull the drive out, feel free to give the back connector a quick puff of air, now carefully place the drive back into the laptop so that it's nice and tight.
Check to see if that solves your problem.
If not we'll try something else.
Feb 22, 2009 | Toshiba Satellite A205-S4707 Notebook
Toshiba A205-S4707 Display issues
This happens when the Mother board, which is the place were all the cables meet inside the computer might not be working correctly. This process needs to be handle by a professional to change the Mother Board.
Thank You!
Jul 23, 2008 | Toshiba Satellite A205-S4617 Notebook
Internet access
Damn you should have an internet connection first.
Then buy a modem or a internet card (for broadband or any other type).
Install the drivers.
Goto start then control panel\network and internet connection and create an internet connection depending on the type you subscribe.
Or alternately don't do anything ask the customer care to setup it for you.
Nov 24, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite A205-S4707 Notebook Logo
250 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
