Question about D-Link (DIR-130) Router
Want to make a network connection between two office 800 meters.
Everybody, I wish to connect two offices approx 800 meters apart for data transfer. How could I connect both the offices using any devices of D-link or other brand.
plz suggest.
Thanks in advance.
Buy 2 DIR 130 VPN routers and connect the two office networks via LAN-LAN VPN tunnels.
If you have the time and skills you can build two IPCOP firewall routers and connect via VPN tunnels (http://sourceforge.net/apps/trac/ipcop/wiki)
Posted on Apr 07, 2010
Hi!
if the two offices has an internet connection you can connect them through vpn connection just buy vpn router.
Posted on Mar 03, 2009
Packet data problem
Hi buddy,
The packet data connection will available for u only when u have subscribed to the network for GPRS like airtel(Mobile office),Vodafone(Vodafone Live) etc. Then only ur problem will be solved.
1. For subscribing to the Mobile office of airtel n/w sms GPRSACT to 222, For settings sms MO to 52586.
2. for subscribing to the Vodafone live of Vodafone n/w sms ACT VL to 141.
I hope this will help u.
Aug 05, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
I want to connect at home
Around the office, your laptop is probably connected to a wireless network which you don't have at home. To connect, you would need to connect to the office network from your home through a VPN (Virtual Private Network) over the Internet or through a dial-up (ugh!) connection to the office systems. Your office IT staff should be able to help you get that set up since either way it would require some configuration on their end to allow you to connect remotely to the office systems.
Apr 18, 2009 | Dell Latitude D600 Notebook
I could not log in to Gtalkn
please, check out your internet settings for google in your office
or
you can contact the system administrator, whether the google option is disabled or any server related issue for your pc.
bye,
Jan 27, 2009 | Google Talk
2 NICs connecting to 2 different networks
you need to speak to your network administrator, for printers you get network enabled printers ( your network admin will assign an IP address and sharenames for your printers,
your network admin can create shared volumes on the network and can sort out internet routing that complies with the corporate domain.
sorry no easy way to do this
Oct 04, 2008 | Compaq Presario 5000 PC Desktop
Exchange server access problem.
If your cisco vpn client is behind the natted device then you need to allow nat traversal in the head office firewall and if you connect the vpn client through data card it will connect,
Aug 01, 2008 | D-Link NetDefend DFL-700 Firewall
3COM Office Connect 3CRUSB10075
are you using windows xp? vista? 98?
I'll guess at xp.(and that you're using the windows software to connect)
Double click the wireless connection icon in the bottom right (the one that flickered when you're online.
Click 'view wireless connections'
click 'change the order of preferred networks'
Now select everything on the list and delete it apart from your own.
Now click 'advanced'
make sure 'automatically connect to non-prefurred networks' is NOT ticked.
Click close, then ok.
You should be ok now.
Regards
Tony
Feb 28, 2008 | 3Com (3CRUSB10075) 802.11g/b Wireless...
IP Phone available for IP office?
Hi TexasTom,
I'm not quite clear on your problem. But I think what your describing would be difficult to archive. That's if I understand you correctly!
Perhaps what you might want to consider is this sort of device. It allows to normal (PSTN) telephones to be used as either SIP (VoIP) or as normal PSTN telephones. It does not require a PC once it's been set-up.
Hope this helps.
Kind regards,
Spare head 2.
Jan 04, 2008 | Avaya 5610 IP Phone
Network between two remote location within City limits
well...first problem is you're going to have big network problems with both sites on the same network/subnet. Based on what you typed above, you will not be able to route packets between the offices since the router won't know which way to go...they must be different networks/subnets...e.g. 10.10.11.0 You have quite a question there...I think you need to have a consultant talk with you over the phone at the minimum. If you can't find one locally you're welcome to work with us. Good luck
Sep 09, 2007 | Computers & Internet
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
D-Link (DIR-130) Router Logo
399 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
