Question about Dryers
Hi, i have a hotpoint aquarius dryer T21, the problem i have is very slow drying. I have removed the back and the heating springs are all still intact but the ceramic holders are all broken. When switched on the parts of the springs heat up but then keep going off and coming back on. they seem to be off a lot more that they are on. I have tried changing between full heat and half heat and it made no differance. I take it the springs are meant to come on and off, but should they be on a lot longer than they are, and how long should they "glow hot" before going off. ????????? Thanks
  • hempland Mar 05, 2009
    Genius:
  • 2,035 Answers
If the heater is heating and not enough then it is the problem with thermostat
replace it ,as it controls the heating time on the washer.....
Good luck...
Posted on Mar 05, 2009
  • 583 Answers
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
thanks and rate the solution accordingly
    Sergeant:
  • 270 Answers
It may be the circuit problem.so yuo send it to a service center.
Posted on Mar 03, 2009
    President:
  • 1,952 Answers
The element is in 2 parts.one element is on for low heat and two for high heat.sounds like the low heat has blown but its the whole two elements that you replace as they are in one unit.
  • 4 more comments
  • mohammed marika thambi
    mohammed marika thambi Mar 03, 2009
    Often a
    dryer heating element burns out, but doesn't trip the circuit breaker
    or blow a fuse. The heating element is simply a long coil of special
    wire. You can check it for continuity with an ohm meter. No continuity
    means the element is bad and you need to replace it--electric heating
    elements aren't repairable.
    Vent
    Heating element
    Internal ductwork
    Cycling thermostat
    Vent
    Frequently
    Heating element
    Your
    Internal ductwork
    Your
    repair technician.
    Cycling thermostat
    Although
    Usually
    when an electric dryer overheats it's because of a defective cycling
    thermostat or a clogged vent system. Clean any lint from the internal
    and external ductwork, and/or replace the cycling thermostat (read
    about cycling thermostats in "Drying is too slow," above).
    If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
    always
    disconnect your appliance from its power source--that is, unplug it or
    break the connection at the circuit breaker or fuse box--before you do
    any troubleshooting or repair work on your appliance. Also, because
    some components may have sharp edges, use caution while working on your
    appliance.
    Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:so yousend it to a service center.
    always
    appliance.
    Brigadier General:
  • 8,619 Answers
Hi
You need to replace the broken ceramic holders first. Also, check for circuit breaker for the heating element.
  • Rylee Smith
    Rylee Smith Mar 03, 2009
    Also, check for the electrical connections for any short in the wire--
    Also, On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) it often quits but the motor will still run.
    If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
    This is how a thermal fuse looks like---
    Thermal fuse can not be re-set, must be replaced if is open (no continuity between pins).
    Please ask for further clarifications.
    Thanks
    Rylee
  • Rylee Smith
    You can buy a rep[lacement thermal fuse from this link---
    Thermal fuse for hotpoint dryer
Hi my condenser hotpoint Aquarius dryer TCL770 keeps beeping when drying ?? All filters clean ?? Do I need to look at the back by pump maybe .? Thanks
I also have the same dryer with a constant beeping while trying! Did as suggestion 4 and then took the back off, cleaned the heater matrix and thermostats, checked the rear draining pipes...so far so good!
Sep 15, 2014 | Hotpoint Dryers
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
Tumble dryer has stopped working
you can check pump ,if pump isn't working water stay all time .
Feb 20, 2012 | Hotpoint Aquarius WD640 Front Load...
MY HOTPOINT DRYER MODEL TVM560G AQUARIUS IS NOT DRYING WITH ANY HEAT
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Hotpoint Dryers
No heat
Check on the back of the drum for a thermal fuse or relay. Common fault on tubledryers is no power to heating coils becuse of blown fuse or most likely the relay to heating coils is dirty. have to be cleaned about every 2/3 years depending on use.
Aug 09, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
Dryer problrm
The sympoms are typical of a couple of reasons.
  1. Blocked condenser.
  2. faulty cold inlet valve, not letting water in to condense steam back to water.
When it is on the drying cycle, see if you can see water pumping out of the drain at. a slow rate.
If you can see no water at all coming from outlet hose, then chances are it is a faulty valve, and you will have replace same.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Drier Motor
Disconnect the vent at the back of the dryer and dry a load unvented to make sure you don't have a clog in the vent line too the outside causing an air flow restriction, if still not drying check and make sure the blower wheel that circulates the heat inside the dryer isn't broken.
Jul 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
71 people viewed this question
Top Dryers Experts
