Question about Intel Compaq EVO D500 (RBMDTCPQP42400) PC Desktop
The computer does'nt shows the graphics when started
When I start the computer, the process run up to the stage of displaying the words XP WINDOWS. And then the computer stags and the process stops.But the cursor or pointer appear on the screen,and able to move when the mouse is moved.
    Scholar:
  • 142 Answers
Find the recover cd that came with your computer and when asked to reinstall or repair choose repair. Larry
Posted on Mar 04, 2009
My GX520 pwr light is green, on the board is an amber Led, the somputer boots up, it goes the full process, until the arrow appears on the monitor. no Iconn are displayed on the desktop
If your computer gets to that stage, then I would guess you have an OS ( Operating System ) problem. Try booting from your XP installation CD. If that works then you may have to re-install Windows.
Jun 23, 2012 | Dell OptiPlex GX520 PC Desktop
Tip
Change Text on XP Start Button
Step 1 - Modify Explorer.exe File
In order to make the changes, the file explorer.exe located at C:\Windows needs to be edited. Since explorer.exe is a binary file it requires a special editor. For purposes of this article I have used Resource Hacker. Resource HackerTM is a freeware utility to view, modify, rename, add, delete and extract resources in 32bit windows executables and resource files (*.res). It incorporates an internal resource script compiler and decompiler and works on Microsoft Windows 95/98/ME, Windows NT, Windows 2000 and Windows XP operating systems.
get this form
h**p://delphi.icm.edu/pl/ftp/tools/ReSHack.zip
The first step is to make backup copy of the file explorer.exe located at c:\windows\explorer. Place it in a folder somewhere on your hard drive where it will be safe. Start Resource hacker and open explorer.exe located at c:\windows\explorer.exe
The category we are going to be using is "string Table". Expand it by clicking the plus sign then navigate down to expand string 37 followed by highlight 1033. If you are using the Classic Layout rather that the XP Layout, use number 38. The right hand pane will display the stringtable. We're going to modify item 578, currently showing the word "start" just as it displays on the current Start button.
There is no magic here. Just double click on the word "start" so that it's highlighted, making sure the quotation marks are not part of the highlight. They remain in place, surrounding the new text that you'll type. Go ahead and type your new entry. In my case I used Click Me!
You'll notice that after the new text string has been entered the Compile Script button that was grayed out is now active. I won't get into what's involved in compiling a script, but suffice it to say it's going to make this exercise worthwhile. Click Compile Script and then save the altered file using the save us command on the File Menu. Do not use the Save As command and choose a name for the file. Save the newly named file to C:\Windows.
Step 2 - Modify the Registry
! ! !make a backup of your registry before making changes! ! !
Now that the modified explorer.exe has been created it's necessary to modify the registry so the file will be recognized when the user logs on to the system. If you don't know how to access the registry I'm not sure this article is for you, but just in case it's a temporary memory lapse, go to start (soon to be something else) Run and type regedit in the open field.Navigate to:
HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\Windows NT\ CurrentVersion\ Winlogon
In the right pane, double click the "shell" entry to open the Edit String dialog box. In the value data: line, enter the name that was used to save the modified explorer.exe file. Click OK.
Close Registry Editor and either log off the system and log back in, reboot the entire system if that's your preference. If all went as planned you should see your new Start button with the revised text.[/b]
on Jan 02, 2010 | Computers & Internet
Tip
NTOSKRNL.EXE is missing or corrupt.
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
on Dec 27, 2009 | Computers & Internet
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
Tip
Some of the important cmd prompt commands
Copy and keep it handy..
ADDUSERS --Add or list users to/from a CSV file
ARP -- Address Resolution Protocol
ASSOC -- Change file extension associations
ASSOCIAT --One step file association
AT -- Schedule a command to run at a later time
ATTRIB --Change file attributes
BOOTCFG --Edit Windows boot settings
BROWSTAT --Get domain, browser and PDC info
CACLS -- Change file permissions
CALL --Call one batch program from another
CD --Change Directory - move to a specific Folder
CHANGE-- Change Terminal Server Session properties
CHKDSK -- Check Disk - check and repair disk problems
CHKNTFS -- Check the NTFS file system
CHOICE --Accept keyboard input to a batch file
CIPHER --Encrypt or Decrypt files/folders
CleanMgr ---Automated cleanup of Temp files, recycle bin
CLEARMEM ---Clear memory leaks
CLIP ---Copy STDIN to the Windows clipboard.
CLS ---Clear the screen
CLUSTER ---Windows Clustering
CMD ---Start a new CMD shell
COLOR --- Change colors of the CMD window
COMP ---Compare the contents of two files or sets of files
COMPACT --- Compress files or folders on an NTFS partition
COMPRESS ---Compress individual files on an NTFS partition
CON2PRT ---Connect or disconnect a Printer
CONVERT ---Convert a FAT drive to NTFS.
COPY ---Copy one or more files to another location
CSCcmd ---Client-side caching (Offline Files)
CSVDE ---Import or Export Active Directory data
DATE --- Display or set the date
Dcomcnfg DCOM ---Configuration Utility
DEFRAG ---Defragment hard drive
DEL ---Delete one or more files
DELPROF--- Delete NT user profiles
DELTREE ---Delete a folder and all subfolders
DevCon ---Device Manager Command Line Utility
DIR ---Display a list of files and folders
DIRUSE --- Display disk usage
DISKCOMP--- Compare the contents of two floppy disks
DISKCOPY ---Copy the contents of one floppy disk to another
DNSSTAT ---DNS Statistics
DOSKEY --- Edit command line, recall commands, and create macros
DSADD ---Add user (computer, group..) to active directory
DSQUERY--- List items in active directory
DSMOD ---Modify user (computer, group..) in active directory
ECHO--- Display message on screen
ENDLOCAL--- End localisation of environment changes in a batch file
ERASE ---Delete one or more files
EXIT ---Quit the current script/routine and set an errorlevel.
EXPAND --- Uncompress files
EXTRACT--- Uncompress CAB files
FC--- Compare two files
FDISK--- Disk Format and partition
FIND ---Search for a text string in a file
FINDSTR--- Search for strings in files
FOR /F ---Loop command: against a set of files
FOR /F ---Loop command: against the results of another command
FOR ---Loop command: all options Files, Directory, List
FORFILES ---Batch process multiple files
FORMAT ---Format a disk
FREEDISK ---Check free disk space (in bytes)
FSUTIL --- File and Volume utilities
FTP --- File Transfer Protocol
FTYPE--- Display or modify file types used in file extension associations
GLOBAL --- Display membership of global groups
GOTO ---Direct a batch program to jump to a labelled line
HELP--- Online Help
HFNETCHK--- Network Security Hotfix Checker
IF--- Conditionally perform a command
IFMEMBER Is the current user in an NT Workgroup
IPCONFIG Configure IP
KILL Remove a program from memory
LABEL --- Edit a disk label
LOCAL --- Display membership of local groups
LOGEVENT--- Write text to the NT event viewer.
LOGOFF --- Log a user off
LOGTIME --- Log the date and time in a file
MAPISEND ---Send email from the command line
MEM --- Display memory usage
MD --- Create new folders
MKLINK --- Create a symbolic link (linkd)
MODE ---Configure a system device
MORE --- Display output, one screen at a time
MOUNTVOL ----Manage a volume mount point
MOVE --- Move files from one folder to another
MOVEUSER--- Move a user from one domain to another
MSG ---Send a message
MSIEXEC --- Microsoft Windows Installer
MSINFO ---Windows NT diagnostics
MSTSC --- Terminal Server Connection (Remote Desktop Protocol)
MUNGE --- Find and Replace text within file(s)
MV --- Copy in-use files
NET --- Manage network resources
NETDOM --- Domain Manager
NETSH ---Configure network protocols
NETSVC ---Command-line Service Controller
NBTSTAT --- Display networking statistics (NetBIOS over TCP/IP)
NETSTAT --- Display networking statistics (TCP/IP)
NOW --- Display the current Date and Time
NSLOOKUP--- Name server lookup
NTBACKUP ---Backup folders to tape
NTRIGHTS E---dit user account rights
PATH --- Display or set a search path for executable files
PATHPING ---Trace route plus network latency and packet loss
PAUSE --- Suspend processing of a batch file and display a message
PERMS --- Show permissions for a user
PERFMON ---Performance Monitor
PING ---Test a network connection
POPD --- Restore the previous value of the current directory saved by PUSHD
PORTQRY--- Display the status of ports and services
PRINT --- Print a text file
PRNCNFG --- Display, configure or rename a printer
PRNMNGR --- Add, delete, list printers set the default printer
PROMPT --- Change the command prompt
PsExec --- Execute process remotely
PsFile --- Show files opened remotely
PsGetSid --- Display the SID of a computer or a user
PsInfo ---List information about a system
PsKill --- Kill processes by name or process ID
PsList --- List detailed information about processes
PsLoggedOn ---Who's logged on (locally or via resource sharing)
PsLogList ---Event log records
PsPasswd --- Change account password
PsService --- View and control services
PsShutdown ---Shutdown or reboot a computer
PsSuspend ---Suspend processes
PUSHD --- Save and then change the current directory
QGREP --- Search file(s) for lines that match a given pattern.
RASDIAL ---Manage RAS connections
RASPHONE ---Manage RAS connections
RECOVER --- Recover a damaged file from a defective disk.
REG --- Registry: Read, Set, Export, Delete keys and values
REGEDIT --- Import or export registry settings
REGSVR32--- Register or unregister a DLL
REGINI ---Change Registry Permissions
REM --- Record comments (remarks) in a batch file
REN --- Rename a file or files.
REPLACE --- Replace or update one file with another
RD ---Delete folder(s) [remove dir]
RDISK ---Create a Recovery Disk
RMTSHARE ---Share a folder or a printer
ROBOCOPY--- Robust File and Folder Copy
ROUTE --- Manipulate network routing tables
RUNAS --- Execute a program under a different user account
RUNDLL32--- Run a DLL command (add/remove print connections)
SC --- Service Control
SCHTASKS--- Create or Edit Scheduled Tasks
SCLIST --- Display NT Services
ScriptIt Control ---GUI applications
SET --- Display, set, or remove environment variables
SETLOCAL--- Control the visibility of environment variables
SETX ---Set environment variables permanently
SHARE --- List or edit a file share or print share
SHIFT --- Shift the position of replaceable parameters in a batch file
SHORTCUT ---Create a windows shortcut (.LNK file)
SHOWGRPS ---List the NT Workgroups a user has joined
SHOWMBRS ---List the Users who are members of a Workgroup
SHUTDOWN ---Shutdown the computer
SLEEP --- Wait for x seconds
SOON --- Schedule a command to run in the near future
SORT --- Sort input
START --- Start a separate window to run a specified program or command
SU ---Switch User
SUBINACL ---Edit file and folder Permissions, Ownership and Domain
SUBST --- Associate a path with a drive letter
SYSTEMINFO--- List system configuration
TASKLIST--- List running applications and services
TIME ---Display or set the system time
TIMEOUT--- Delay processing of a batch file
TITLE --- Set the window title for a CMD.EXE session
TOUCH --- Change file timestamps
TRACERT --- Trace route to a remote host
TREE --- Graphical display of folder structure
TYPE --- Display the contents of a text file
USRSTAT--- List domain usernames and last login
VER ---Display version information
VERIFY --- Verify that files have been saved
VOL --- Display a disk label
WHERE --- Locate and display files in a directory tree
WHOAMI --- Output the current UserName and domain
WINDIFF --- Compare the contents of two files or sets of files
WINMSD --- Windows system diagnostics
WINMSDP--- Windows system diagnostics II
WMIC ---WMI Commands
XCACLS --- Change file permissions
XCOPY--- Copy files and folders
on Dec 16, 2009 | Computers & Internet
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
Desktop will not start.. will only go through Chkdsk
Try and tap F8 and see if you can boot to safe mode and go to my computer and rt click on C, and pick properties then tools, then
check for errors, and check auto,and scan.
Go to dell.com if you don't know who made the hard drive in your model. Then go to the mfg of the hard drive and download a hard drive diagnostic disk to check your hard drive for bad sectors.
You should go to dell.com and check your warranty and you can also ask dell what you should do.
This link posted below has a lot of drive mfg diagnostic tools.
http://www.tacktech.com/display.cfm?ttid=287
Apr 14, 2009 | Dell Dimension 9200 PC Desktop
Desktop view problem
go to new task and make sure you enable Windows Explorer.
Mar 05, 2009 | HP Computers & Internet
Error: windows root>\system32\ntoskrnl.exe
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
Intel Compaq EVO D500 (RBMDTCPQP42400) PC Desktop Logo
69 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
