Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
I installed a toshiba mk3008gal into my zune and the zune is no longer reacting. I was replacing an old broken hard drive
    Problem Solver:
  • 5 Answers
Iv'e done the same, and reupdated from the zune page. Then downloaded all my music from my saved files.
Posted on Mar 20, 2009
  • 66 Answers
I would think you need to reinstall the firmware. That or maybe your zune doesnt work with that drive.
Posted on Mar 12, 2009
How to repair toshiba hard drive mk3008gal
oopppssss.. clicking sounds and no response from a hard drive usually means its DEAD!!...any data is probably unrecoverable.. - sorry
Aug 10, 2017 | Toshiba MK3008GAL Hard Drive
E05A100PBU3XS toshiba hard drive no longer recognized
For internal hard-drive:
There's a possibility that the hard drive is cooked. Try running a hard-drive self test by accessing the BIOS screen of your laptop. If the test fails, the your hard-drive is already broken.
Try re-seating your hard-drive. Take it out then put it back in again. If it doesn't work, the hard-drive is broken. If you have a similar drive available, try replacing the drive that displays the error. If the extra drive works without any problems, the old drive is broken.
Consult a local technician. They should be able to assist you in resolving problems like this. They might also be able to help you retrieve important data from the broken drive.
You can also call your computer's manufacturer for troubleshooting or replacements.
For external drives.
Fixes:
1. Plug the hard-drive into another port. 2. Plug the hard-drive to another computer. If you get the same error, the drive is no longer usable.
Sep 21, 2011 | Toshiba Notebooks Canvio E05a100pbu3xs 1...
I have a 30 GB Zune (Model 1089) that keeps encountering problems (Headphone Jack, etc.) I also have an iPod Classic 80 GB (w/ a broken hard drive). Is there any way that I can put the hard drive from my...
You would probably encounter less problems just replacing your iPod's HD with a new one.
RapidRepair sells them for $110 for an 80g, and their instructions are pretty good.
http://www.rapidrepair.com/shop/1817-80gb-hard-drive-ipod-classic.html
Here's the Toshiba version of the iPod Drive-
http://sdd.toshiba.com/main.aspx?Path=StorageSolutions/1.8-inchHardDiskDrives/MK8022GAA/MK8022GAASpecifications
And here's the Toshiba version of the Zune drive-
http://sdd.toshiba.com/main.aspx?Path=StorageSolutions/1.8-inchHardDiskDrives/MK3008GAL/MK3008GALSpecifications
It looks like they might actually be interchangable, but in my experience 1st Gen Zunes have a lot of problems, especially with the batteries and HD's.
Sep 09, 2011 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I have a Toshiba MK3008GAL hard drive that I pulled out of my Zune because the Zune itself is freezing a ton! I would like to be able to get the music that is on the hard drive off. I have attempted to use...
You will need a docking station but you don't say whether the drive has an IDE or Sata connection. IDE being older and sata is current. Your pc will just see it as another device and will let you explore the files and copy them.
Aug 01, 2017 | Toshiba MK3008GAL Hard Drive
Good evening wish you. I use the MK3008GAL HDD in Acer Aspire One 110Aw netbook (original was 8GB SSD). The system appears to be Secondary Master. Why? Can be set as Primary Master? Infrequently heard...
Most motherboards have two "channels", namely PRIMARY and SECONDARY.
Each channel can support two devices, namely MASTER and SLAVE.
So, the "data" cable from your disk-drive is connected to the SECONDARY channel,
and is the MASTER (or maybe "only") device on that channel.
Connecting it to the PRIMARY channel will *NOT* increase the performance of your computer; don't waste your time trying to change it.
Yes, Toshiba disk-drives do "click". However, given that you *DO* have "bad" sectors, you need to replace the disk-drive before it *COMPLETELY* dies, causing the loss of all your files!
Make a BACKUP of all your files, today!
Dec 18, 2010 | Toshiba MK3008GAL Hard Drive
I purchased a new Toshiba MK3008GAL 30GB hard drive for a Zune. I installed the drive and it powers up. I have formated the Zune and tried to reload the firmware but get an out of space error code...
yes take it out and then put the bad oe back in and power it back up and it will rest code then pull the bad one back out and put the good one back in hook it back up then power it up whith the zune program running who must have windows 7 to make it work right if have more ? email at master142838@hotmail.com
Nov 06, 2010 | Toshiba MK3008GAL Hard Drive
I recently bought a Toshiba Satalite laptop to replace the one I dropped which was also a Toshiba Satalite. I had taken out the old hard drive and installed it in the new one but now it wont do anything...
Yes it does matter. XP was configured for the old Toshiba and this will only work if both Toshiba laptops are exactly the same model.
To get your new Toshiba operating, put the new hard drive with the Vista operating system back in the Toshiba laptop.
To transfer your data from the old hard drive, purchase a USB adapter hard drive case and place the old hard drive inside this case. This will then be an external USB hard drive.
Plug this USB hard drive into the new Toshiba's USB port and it will detect it as an external storage/hard drive. You can then open the various folders and files and copy the data files to your new Toshiba.
To free up disk space on this USB hard drive, delete the Windows folder, Program Files folder and other folders that are no longer needed.
Use this hard drive as a backup hard drive etc.
Sep 11, 2010 | Toshiba Computers & Internet
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
142 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
