Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
PC start directly
Dear Sir,
I have one problem is that when i open the pc from main switch it has open direclty without touch the pc startup button even i shut it down properly.When i power on pc by main power button then give a beep and appear on screen F4 for reset time and date. I have to do set it every time when i start it. I have change my pc battery also still problem continue. Please help me.
  • sanjay142 Mar 03, 2009
    I open the pc mean When normally when people start pc first put Main switch and then power button of CPU. In my case When I start Main switch PC starts from Power automatically even I don't press power button of CPU, then after one beep and screen ask to press F4 This will reset time and date also in cmos
  • Frank
    Frank May 11, 2010
    check the CMOS locked pin on the motherboard.
    Scholar:
  • 157 Answers
Reset the bios jumper
Posted on Mar 03, 2009
    Sergeant:
    Champion:
  • 315 Answers
Explain what you mean when you say 'when i open the pc from main switch'.
Also, something you should try is updating the CMOS, or in other words flashing the BIOS firmware. Go to your motherboards manufacturers website and see if there are any BIOS updates for it.
Dear sir
i am change cmos battery but my problem is not solf
plz help me
Posted on Aug 25, 2009
I need the main login password for a compaq 2103
At some point someone installed a BIOS password on your PC. Open CPU >move Jumper 2 2-3 pstn from 1-2 >start PC >Go to BIOS >clear it >turn off>move the jumper back to the original position. Restart PC. Be careful you have touched bare metal before touching anything on the motherboard. You don't want to zap it with static electricity.
Jan 17, 2013 | Compaq CQ2103WM-B (884962083048) 17 in. PC...
Tip
Having slow performance? Make your PC/laptop run faster (only for WIndows XP)
There are some steps which you can try to boost your Windows XP PC/Laptop's speed & performance:
1) Removing Startup items
Click Start, point to Programs, click Startup, and then right-click each item in Startup and select Delete. Your Startup folder should be empty
2) Remove unnecessary programs from Add & remove programs list
Click Start, point to Settings, and click Control Panel. Double-click Add or Remove Programs icon.
Scroll through the list of installed programs, and remove the one you don’t need. Be sure about the programs those you don't need.
3) Setting PC/Laptop for best performance
Right-click My Computer and select Properties.
Switch to Advanced tab and click the Settings button under Performance subsection. Performance Options window will open.
Select Adjust For Best Performance option and click OK button.
This may degrade the looks but will increase the performance of PC/Laptop.
4) Right-click My Computer and select Manage. Computer Management window will open. Maximize Computer Management window.
Click plus sign next to Services and Applications, click Services, and switch to Standard tab on the right.
Disable the following services one by one:
Alerter
Background Intelligent Transfer Service
ClipBook
Error Reporting Service
Fast User Switching Compatibility
Help and Support (switch to Manual)
Indexing Service
Messenger
NetMeeting Remote Desktop Sharing
Performance Logs and Alerts
QoS RSVP
Remote Desktop Help Session Manager
Remote Registry
Telnet
Upload Manager
WebClient
Wireless Zero Configuration (don’t disable if using wireless network/Internet connection)
To disable the service, search the service name in the list of services & double-click on it. Change Startup Type for the service, selecting Disabled from Startup type dropdown box and clicking OK button.
Restart the computer.
5) Run CCleaner regularly.
Download CCleaner application from here. Install it.
Run it time to time to run your PC smoothly.
6) Defragment hard drive (may take up to 30 minutes or more than that)
Click Start, select Programs, Accessories, System Tools, and click Disk Defragmenter.
When Disk Defragmenter window opens, select a drive in the top portion of the window, and click Defragment button.
on Jun 15, 2010 | Computers & Internet
MOBILE: nokia supernova 7210 Sir, when I press 'GO TO' button and go to a special option my phone will be switched off, and if I press 'GO TO' button main Menu will not be opened with out switch offing...
Download Nokia Software Updater on Nokia's official website and install it in your PC. Connect it using a USB data cable and then update your firmware
Mar 28, 2011 | Nokia 7210
Shut down
Go to the control panel select power option and check the settings.
Mar 30, 2010 | E-Machines eMachines Desktop PC
I have a toshiba satellite a45 s150 and i replaced the hinges and put it back together and now the power wont come on and i see an error light flashing
just try with removing the battery and also see the when you fixing the hinges there are no wire stuck inside in hinges. direclty connect the main power and start without battery.
Jan 30, 2010 | Computers & Internet
Hello..my acer aspire 4520 does not on if i press the power button..if i plug the power adapter the battery light blink continiously..can u please tell me wat is the problem..
just conncet the power cord and leave the laptop fro 10 -15 minutes and then try to on if it on well otherwise remove the battery and direclty switch on the laptop on main power.
Jan 20, 2010 | Acer Aspire 4520-5582 Notebook
Startup main error problem
Depending on the operating system your running, click on the start button in the bottom left or the vista icon, then either click on "RUN" or in the search box type MSCONFIG and press enter.
Click on the startup tab and then clickon the disable all button. Then click on apply and then okay and then let the computer restart.
After it restarts if the error message stops appearing then you know its something that is starting up when windows boots.
Go back into msconfig and then you can enable any of the programs that you want to startup instead of the ones that you don't.
May 24, 2009 | Acer Aspire One PC Notebook
Sound was stopped by pushing sound symbol on HP monitor.
click on the start button >> select Run. In the Run box type "services.msc" without the quotes and press Enter.
Services window will open up, select "windows audio" from the list, double click on it, the startup type should be Automatic and then click on Start button to start this service. Problem should be solved by now.
Mar 28, 2009 | HP Pavilion Media Center a1330n - AMD...
No sound from subwoofer just a humming sound
Mar 28, 2009 | Dell Dimension 2400 PC Desktop
Pc start dirctly even i shut it down properly
Appears that the jumper is actually in the "reset" position or possibly the battery is no good.
Dec 30, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
257 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
