Question about Gateway Computers & Internet
My display is garbled. I can hardly read the letters because of characters which shows up. Is the video card separate or integrated with the motherboard? Are there available video cards or motherboards which I can replace my notebook? Btw, my notebook is an Emachines M6085. Thanks for your help
  • lyndonmac23 Mar 03, 2009
    It is not the backlight or inverter because the lcd is very bright. Its just the characters that appears in the lcd which covers the whole screen. When I used an external video, it has the same appearance as my lcd which is garbled. So, I think its the video card. Then I have to replace the motherboard, right? Thanks for your help. Appreciate it a lot!
  • Gateway Master
  • 32,281 Answers
I don't know any laptops that have separate video cards, they are integrated with the motherboard.
To test if the video card is faulty, connect an external monitor to the laptop's external video connector/port and boot up your laptop. The external monitor may automatically display images, if not you may have to press the blue Fn key plus one of thr function keys to switch the video output to this video port. If you see a clear image the the Video card is OK and the LCD is faulty.
Is the display garbled or it is very dim?
If it is dim and the image is OK then the problem is associated with the backlight. It could be the inverter that supplies high voltage to the CCFL lamp or the CCFL lamp is faulty and 80% of the time it is the CCFL lamp.
The inverter is easy to replace but the CCFL lamp requires more work and soldering skills.
Go to for parts and repair services and DIY instructions..
Posted on Mar 03, 2009
No display
IF YOU HAVE INTEGRATED VIDEO (on your motherboard):
>exchange your monitor with a different one
>exchange the monitor video cable with another
>If no help, get a separate video card and install it; if you now get display, your integrated video failed. You will need to use a separate card.
>IF YOU HAVE A SEPARATE VIDEO CARD: remove, clean the contacts with a soft pencil eraser (be gentle!) and reinstall. Make sure it is seated evenly, all the way down and locked in place. Make sure the monitor cable is plugged in properly and the socket is not damaged.
>If all above fails, possibly your motherboard video failed.
Oct 07, 2013 | Computers & Internet
Pc is on but no display
>Change video cable to test. Make sure it is plugged in firmly with no damaged/bend pins in the plug.
>Change monitors; if you get display with a different one your monitor failed
>IF you have a separate video card, remove and reinstall; GENTLY clean the contacts and make sure it is installed firmly.
>If you have integrated video on the motherboard (most PCs do now), get a video card and install it in the correct slot. If you get display, the integrated video on your motherboard failed. Use the new card instead. Don't forget to install the drivers for the video card.
>If all above fail, your motherboard failed.
Oct 02, 2013 | Computers & Internet
If you are not getting any display but no beep sound (beep sound would mean a RAM problem) check the video cable for bent pins or try to unplug and replug the video cable. if nothing happens. you can just add separate video card because the integrated video card is not working fine. Thanks
Jan 04, 2011 | Intel Computers & Internet
When I turn on the power on my thinkpad the picture on the monitor is garbled and it's almost near impossible to get it ungarbled. It does it right when it starts up
connect an external monitor and check how is the display,if the display is fine on external monitor,then it would be your
If you are getting the garbled picture on the external monitor also it could be
SHARED MEMORY AT FAULT( If the laptop uses shared video memory (part of the main memory is used for the video purposes), it's possible that you have a faulty RAM stick.)
VIDEO CARD (if the video card is discrete replace take out that and check the video with integrated video card and if the video card is integrated then you have to replace the mother board)
Sep 17, 2010 | IBM ThinkPad A31 Notebook
I feel that the mother bd went bad. the laptop is dead. I have the MD out and cant find the part number on it anywhere?
The motherboard should have a 20 character ID number similiar to this: CN-0WY041-48943-78L-2194 The 4th thru 8th digits are the part number (In the example WY041)
WY041 and MP313 are Motherboards that use a separate discrete video card. NX906 uses Intel Integrated Graphics and requires no separate video card.
Replacements can be found here:
Nov 14, 2009 | Dell Vostro 1500 Notebook
Xerox Phaser 6350 Control Panel display problem
If your display has a blank display, displays garbled characters, or the display is inverted or upside down, check out this video
Sep 10, 2009 | Xerox Phaser 6350/YDT Laser Printer
I m looking for multimedia audio controller driver,but i dont know sound card name.
first your pc model second your sound card is integrated or separated one?
if integrated send to me your pc model and i send to you solution, second if it is separated open your pc case and witth a mirror without moving sound card from place try to look at dhe chip the letters and numbers writen there and send to me for a solution too.
Apr 05, 2009 | Dell Computers & Internet
Kingston Flash Memory not working
could be a bad card or the card reader/writer does not support that high of a capacity memory card.
Feb 05, 2009 | Kingston flash memory card - 256 MB -...
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
Jun 17, 2008 | NorStar Meridian M7310 Phone
from WIKI:
A video card, also referred to as a graphics accelerator card, display adapter, graphics card, and numerous other terms, is an item of personal computer hardware whose function is to generate and output images to a display. It operates on similar principles as a sound card or other peripheral devices.
The term is usually used to refer to a separate, dedicated expansion card that is plugged into a slot on the computer's motherboard, as opposed to a graphics controller integrated into the motherboard chipset. An integrated graphics controller may be referred to as an "integrated graphics processor" (IGP).
next time do some research. GOOGLE it.
Jun 11, 2008 | Computers & Internet
Computers & Internet Logo
356 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
