Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Help error code 30, and now after trying somethings 'unable to clean' on Brother 240c... thanks
  • 4,041 Answers
Several conditions may cause the error message Machine Error 30, 33, 34 or 35 to be displayed on the LCD. This error may be the result of one of the following:
  • The print head carriage is failing to return to its home position to the far right of the unit.
  • Both of the springs located on each side of the carriage is out of place.
  • The cartridge covers may not be locked securely in place.
Please follow the instructions listed below to correct this problem:
  1. Press the INK button on the Control Panel.
  2. Using the dial pad, press 2 (Replace Ink). The display will prompt you PLS OPEN COVER.
  3. Pull the Scanner Cover release lever located under the Control Panel and lift the Scanner cover. The carriage should move to the left in order to replace the ink. If the carriage does not move to the left, your machine will require service.
    If your machine is still within warranty, click here to locate a Brother Authorized Service Center in your area or click here to obtain contact information for the appropriate Brother Customer Service Center. If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
  4. After the carriage moves to the left, press down each cartridge cover and remove all ink cartridges from the machine. There are 2 springs located on each side of the carriage that hold the print head against the carriage assembly. They are thin silver springs approximately 2 1/2 inches, set at an angle.
  5. If the spring is out of place, press the spring back into place. You can use the spring on the opposite side of the carriage as a guide as to the correct position.
  6. If the spring is not out of place, reinstall each ink cartridge.
  7. After installing the ink cartridges, close the covers and verify they are securely locked into place. Your machine then prepares for a head cleaning and goes online. The LCD screen prompts you to verify if a new ink cartridge was inserted for each color you removed. For example, DID YOU CHANGE BLCK 1. YES 2. NO.
  8. Press 2 (No).
Note If you decided to place a new ink cartridge in for any of the colors when uninstalling and reinstalling the cartridges in the above process, press 1 (Yes). The machine will automatically go through a cleaning cycle.
Also this might be handy for you. To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Please call back and gave us a vote. All The Best: Pineworks
Posted on Mar 02, 2010
"Clean Unable 51" error. I
Click the link below to download the Service / Repair Manual ( Brother MFC-240C) :http://www.mediafire.com/?l39vz2fiqqkl73y
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site
Jul 04, 2011 | Brother MFC 240C All-In-One InkJet Printer
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
Error 30
I have the MFC 465CN - I was receiving two error codes:
Unable To Clean - Error 30
Unable to initialize
To fix, I first cleared the memory by unplugging the printer, then holding down the red stop/exit button, keep it held, power up the printer, and dont let up the button until it finishes the start up.
I then pressed the "ink" button and performed a cleaning, alignment, and quality check. After this, everything worked fine.
DO NOT try to print anything from your computer or have any pending print jobs while doing this - it appears that pending print jobs, or anything in the printers memory was interferring with the initilization and cleaning cycle it performs.
Hope this helps...
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Clean unable 51
Ok Please follow this link and it has your answer.
Please rate me when it was a FIXYA
May 03, 2008 | Brother Multi-Function Center MFC-240C...
Unable to clean
plz search this forum for unable to clean or error 46
it has been explained so many times
Apr 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
260 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
