Question about Air Tools & Compressors
How do I change my atlas lxf 6D-8 compressor over from 3 phase to 1 phase?
    Champion:
  • 205 Answers
Only way to do that is to replace the motor with the same horse power rating and rpm
Posted on Mar 05, 2009
I have a Ingersoll Rand Compressor model# 2545E10V 10 HP,3 phase and I would like to convert it to a signle phase. would this motor here be good to go with and what other items will be needed to complete...
It might. Mounting holes match? Shaft diameter and adapter match? Power supply sufficient for 5HP motor? It's a big motor! You might get a better answer from the ebay supplier.
Mar 05, 2015 | Ingersoll Rand Air Tools & Compressors
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
May 16, 2013 | Ingersoll Rand - Rand Type - 30...
Sometimes IR 30 goes into a strained free wheeling state
Did you change the 3 phase motor out with a single phase motor? A 3 phase motor cannot be made to run on single phase.
Feb 02, 2013 | Ingersoll Rand - Rand Type - 30...
I have an ingersol rand 2420n5 t30 and i want to convert it from single phase to 3 phase any help thanks
Hi robles212
To convert your T-30 to single phase you will have to do one of two things.
1. Change the motor to a single phase motor
2. Buy and install a "Phase Converter" to convert 3 phase to single phase
Please rate me
Bud
Oct 08, 2012 | Ingersoll Rand Type 30 Reciprocating Air...
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
My type 30 slows down when the tank pressure reaches close to 100 psi.. motor is new as this caused old one to burn up,, what can it be?
1. Are you sure the motor is wired for the correct voltage? If you have 230V 3PH,Make sure that you do have 3 hot legs. you should have L1-1+7, L2-2+8, L3-3+9 and 4+5+6 connected together. If it is wired for 480V it will not have enough torque. Check rotation. There should be an arrow on pully (large one on compressor)
Nov 03, 2010 | Ingersoll Rand - Rand Type - 30...
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
Voltage 1phase or 3 phase 240 volts BTUs M# 585epo36o75
Looking at the model number, it appears to be a 3 ton. (36,000 btu) Most all residential units are single phase and most all commercial are 3 phase. One way to tell, look to see if the compressor has a capacitor. 3 phase never use capacitors on the compressors as they are not needed. Some residential units have a "Dual" capacitor. That is, it has 3 terminals, 1 common, 1 for condenser fan motor, and 1 for the compressor. Also, this info should be printed on the unit's lable.
Good Luck and hope this helps.
May 09, 2009 | Amana Comfort Zone 12M32PBEH Air...
Kelvinator model N641n
I have a kelvinator refrigerator, top-mount type model # SKNT 16E.
220V, 1-phase, Defrost amps 1.9, Watts 575,
Gross/Liters 453/396
I have replaced new door gasket.
Freezer gasket is in very condition.
Compressor drawing 3.15amps.
  1. Question is Compressor is working 8 minutes and remains off for 3 minutes.This cycle is happening from some days.Thermostat and timers seem to be ok. Do i need to change Overload cut-out at the compressor or not....please suggest.
masood
masbimed@yahoo.com
Feb 18, 2009 | Refrigerators
Air Tools & Compressors Logo
54 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
