Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Hello-I am being given a Jenn-Air electric range soon. My current electric stove just has the vent pipe coming up under a back element. Will I need to vent the Jenn-air to the outside? I have an over-the-stove microwave that has a ductless fan system. Would that be OK to use instead of the Jenn-Air vent? I'm trying to buy some time to save up in case I have to get it ducted, but want to use it in the meantime. Thanks, Dot
  • elissag Mar 03, 2009
    Thank you so much for the advice. My mind is much more at ease! I just googled and found FixYa--- this site is terrific!!!!
  • 8,197 Answers
Yes the ductless fan will work for you. I have that setup here at my house. Just make sure that you have a charcoal filter installed in the microwave where the air comes out on top. If it is already vent less the filter is probably already there.
Good Luck and Please Rate FixYa!
Posted on Mar 03, 2009
How do you remove old bake elementfrom Jenn Air SVE47001
Pretty simple, make sure you unplug the range or flip the breaker off. Remove the two screws mounting the element to the back wall, carefully pull out the element. It probably has slide on connectors, pull them off and thats it! If you accidentally pull off a wire and it stays back in the stove, you can pull the unit out and remove the back panel and it will be all out in the open.
Jun 17, 2009 | Jenn-Air SVE47100 Slide-In Electric...
How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
Apr 10, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Nov 23, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air Downdraft ducting roof Rack w/flapper
go to www.luxurymetals.com
there are many good high quality vents on the site
Oct 08, 2008 | Jenn-Air HV363 Kitchen Hood
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
144 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
