Question about Boating
My sea ray 195 sport power boat is only 1 year old and has an alarm going off intermitantly almost everytime we use it. It has been in and out of the shop 10 times and had every sensor changed but the alarm persists. Oil temp, water temp all normal indicating a false alarm and the computer telemetry plugged in in the workshop says the alarm did not go off! Any assistance apreciated
  • 07iron May 11, 2010
    What engine is in the boat? Is it carburated or fuel injected? Does the boat have mechanical or digital shifting installed? If the boat has smartcraft gauges, what does the display read when the alarm is going off? Just an after thought, is there anyway it could be a depth alarm - this will sound similar to a soft engine alarm.
SOURCE: Alarm on 2003 115 OPTI MAX
I finally found the problem a defected water pressure sensor.
Posted on Apr 02, 2009
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Posted on Jun 23, 2009
SOURCE: Hi trying to find out the correct way the water
i m search Compaq presario c700 driver but his not find. pls u check it.
thanks
chandra ketu rai
09955129198
Posted on Mar 12, 2010
  • 5636 Answers
SOURCE: i have a 1989 sea ray boat. Does it have no power
If you look at the coil you will see small wires on either side. One side is a ground and the other is power. Depending on the brand of outdrive you have the wires are color coded.
You should be able to see the color of the wires on the "Plus" side at the coil. Then follow the wiring loom back to the switches hanging by the shift cables on the engine. There are also wires on the UP/DOWN safety switches of the outdrive.
The outdrive must be down somewhat for the safety switches to release the ignition LOCKOUT. This is done because the driveshaft will snap if you start the motor with the outdrive up. Look for matching color coded wires to match the small hot coil wires.
The switches on the shift cables will LOCKOUT the starter solenoid so you can only START in neutral. Look for the color coded wires from the coil to see if they are on the correct set of switches. It is possible someone made a redundant connection and combined the ignition with the starter cutoff.
Posted on May 06, 2010
  • 5636 Answers
SOURCE: Boat won't start
Cleaning the plugs is a good idea. Check your gas for fuel separation. Being outside would give you more fluctuations in temperature even without a heated garage. Without any cover the Sun can beat down on the boat. You would not have mold without the heat building under the shrinkwrap. I see some shrinkwrap jobs now using metal vents on them.
Remember the outdrive muffs when you try to start it. Pyroil has a product with oil in the Starting fluid which may help you getting the engine to fire. Also remember to put the outdrive down so the Safety cutoffs are not killing the spark.
Posted on Jun 03, 2010
I have 1998 sea ray
Great, very nice boat. I have a 2014 Boston Whaler 15 Super Sport.
Jun 17, 2017 | Boating
Trim motor will not work on my 1998 sea ray 100 horse power boat
CHECK YOU HAVE POWER TO THE MOTOR USING A TEST METER OR A BULB.
If you have power to it remove it, strip it down and see if you can see what is wrong, or take the unit to a marine engineer.
I have a 1998 sea ray boat trim will not work
Take 12 volt test light to back of switch to see if its hot. Other guess fuse corrosion and fuse holder corrosion. there maybe 2 fuses. 1 "inline" to trim switch other fuse panel.
My 1992 4.3l volvo boat engine has spark and fuel but wont run
I had this issue on my 1988 Sea Ray 4L. Spark may be too weak if your boat has old school points and condenser - gently clean the points contact surface with fine emory sandpaper - see if this works. Otherwise back to basics- Have you checked spark timing? Compression? If those are good would suspect fuel flow ain't what it seems. Good Luck!
Sep 30, 2014 | Boating
1996 29' Sea Ray Sundancer
Maybe Sea Ray can supply the specifics.
Mar 05, 2014 | Boating
Can u use automotive spark plugs on tune up for i/o 1979 sea ray
Use only the spark plug recommended by Sea Ray or the engine manufacturer. Spark plugs in a marine envireonment need to meet special environmental conditions.
Thanks for your quesiton @ FixYa.com
Mar 25, 2012 | Boating
Boating Logo
91 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
