Question about GE WBSE2090A Top Load Washer
Grease Leak My GE 6 cycle washer, model WWA5600, has grease all under the tub and floor. It looks like it need a new belt. Would that be the reason for all the grease?
I know this sounds crazy but we need some replacement tubs for a WWA5600BALWH for a client of ours in Africa who has hundreds of them. GE/Hotpoint have discontinued them. I need to get hold of an old tub to try and back engineer. Any ideas?
Posted on Mar 16, 2009
    Novelist:
  • 117 Answers
Unfortunately not. In addition to replqacing the blet, the transmission must be replaced. It is the only item in your washing machine that contains gear oil. It's a tough job for the do-it-yourselfer...If I can help further, I am here.
Eric Campion
Posted on Mar 03, 2009
Greese spots on laundry from my G.E. washer
need these questions answered 1st in order to address your issue. are the spots black grease as in the type of grease used to lubricate the drum mechanism? also, did you purchase the washer new or used and have you ever had it serviced?
Aug 24, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Ge wwa5600
This video should help you. Not a difficult repair.
Dec 04, 2017 | Washing Machines
Ge wwa5600
You have a faulty timer switch that will need to be replaced. Here is a link to that part to order.
Jun 26, 2013 | Washing Machines
Washer slinging grease from bottom of tub onto sidewalls of washer. Also beginning to leak water while it is agitating and spinning. Do I need Tub Bearing kit?
You need the outer tub seal as a minimum for the water leak. The grease is a different mater, it could come for several places by the most likely in the transmission, not the bearings.
Jun 29, 2011 | Maytag Washing Machines
Grease spot found on the floor from the right side
There is a bearing seal that does tend to leak. Feel free to ask any other questions. I do recommend copy and pasting this link in your internet address bar under a new tab for more great repair info:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 13, 2009 | Maytag LAT3600A Top Load Washer
GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Jun 11, 2009 | GE WDSR2080D Top Load Washer
Grease or oil on floor under washer
try putting a new coupler in it its between the motor an the transmission
Mar 22, 2008 | GE WNSE5260D Top Load Washer
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Grease/oil under washer
Hi, there. Get some one to fix that leak ASAP. The lack of oil will ruin your machine's transmission and/or motor. If you've noticed that your machine runs louder than it used to, then ***stop using it*** until you get the leak repaired. I kept using mine and when it stopped working I couldn't get the parts (a transmission) so I have to get a new one.
Nov 30, 2006 | GE WDSR2080D Top Load Washer
GE WBSE2090A Top Load Washer Logo
325 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
