Question about Panasonic Heating & Cooling
Air con stuck on cooling mode!
I have a panasonic split system a/c even when you change the controller to heat it stays on cooling. please help im freezing.
    Guru:
  • 462 Answers
Is this a Mini Split Ductless type Heat pump? Has it worked in the heat mode for you before? Have you tried killing and reapplying power to both the indoor and out door sections? Does it have a wireless remote? Are the batteries new in it?
I have to assume a lot because there is a lot of information missing to really know how to help you.
If these items helped would you please grade me accordingly. Thank you and GOOD LUCK.
Posted on Mar 03, 2009
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Need to change from cooling to heating for a Kelvinator KSR27G split sys air con. Have tried ourselves using the remote, but we feel it is not operating correctly. No manual came with it when we purchased...
The cooling symbol on the remote is generally an "icicle" , the heating is a symbol of a blazing sun. Make sure you have selected the right mode. Also check the filters... if they are dirty, you wont get decent heating from any air con.. cheers,
BTW, I believe that electrolux have a site you can download instruction books.
Jul 14, 2011 | Heating & Cooling
We have a carriers air con that is about 4 yrs old it has a remote control and digital readings on the unit it is in the wall we can not get it to heat but it does cool we didnt put this in it was here...
Normally all air-cons carry an identifying label on the compressor unit. It has to by law state the gas used. On a split system this would normally be on the outside unit. Sometimes an additional label will be on one of the ends of the inside unit. Some units only do cooling - you need to check once you've found information. Check your remote control 'Mode' setting is correct - it should show a small 'sun' to indicate heating. A small 'icicle' looks similar, but means cooling. Then check temp setting is high enough to cause heating.
Jun 12, 2011 | Carrier Heating & Cooling
DONT KNOW WHAT SIMBLES ON REMOTE CONTROL ARE EG HOT COLD ETC
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Mar 20, 2011 | Mitsubishi MSZ09UN Air Conditioner
Hi i have recently purchased an amcor sPLIT UNIT AND CAN NOT GET THE HEAT TO WORK AND DO YOU HAVER ANY SUGGESTIONS AND PRESUME IT IS A SETTING i AM NOT CORRECTLY PRESSING ? rEGARDS cRAIG
dear sir
please first make turn on your electrical supply for air con
and then use remote controller and find out there heat mode and select it then make your air con on heat mode ..
i hope it will work on heat mode
hope answer the question
thank you
please vote!
Sep 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I havent got a manual for my air con and i want to know how to get one or how to change from heating to cooling
See what you can
find here by typing the following into the search bar:
LG LSC121PMA Split System Air Conditioner?
Nov 02, 2009 | LG LSC121PMA Split System Air Conditioner
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
Heating & Cooling Logo
292 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
