Question about Acer Aspire 5050-3242 Notebook
I LOST IDE ATAPI CONTOLLER
IF I FORMAT MY HARD DRIVE WILL BE ABLE TO REINSTALL XP ON MY LPTOP.
  • Roger Gantner May 11, 2010
    Is this a SATA or IDE drive?
  • Acer Master
  • 1,147 Answers
Yes you can.but you must have a valid xp product key or it will registerit as an acer and will not proceed.i have done it on alot of acers..you will also have to know all the drivers that are for your 5050.you will have to download them all to a cd, then install them ..in the order u download them and it will work fine..youll like it alot better.you should try to create a second partiton for reovery..steve
Posted on Mar 03, 2009
Hard drive capacity
It's 10.2 GB
Maxtor 10.2 GB UDMA/66 7200 RPM IDE Hard Drive
General Features:
10.2 GB formatted capacity
UDMA/66
7200 RPM spindle speed
2 MB buffer
9.0 ms average access time
4.17 ms average latency
E-IDE/ATAPI interface
3.5-inch form factor
Notes:
Drive only
Maxtor model #: 51024U2
Additional Information:
Product Requirements
IDE controller
IDE cable
Available 3.5-inch drive bay
Available 4-pin power connector
Jun 28, 2012 | Maxtor Computers & Internet
Code da620000 what is capacity
It's 10.2 GB
General Features:
UDMA/66
2 MB buffer
Notes:
Drive only
Product Requirements...
IDE controller
IDE cable
Hard drive identification
Here's the specs:
  • Maxtor 20 GB Hard Drive
  • General Features:
  • 20 GB formatted capacity
  • UDMA/100
  • 5400 RPM spindle speed
  • 2 MB buffer
  • 9.5 ms average seek time
  • 5.55 ms average latency
  • E-IDE/ATAPI interface
  • 3.5-inch form factor
Jun 03, 2012 | Maxtor Hard Drive
It is very slow, is not in DMA mode
if you have xp :device manager-ide ata/atapi controller-select your hdd controller-properties-advance sttings-see if are dma available, if not set it.
Apr 19, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
I formated my computer and now it doesn't read the IDE ports
go straight to setup from dos to see if the port is been diabled
Apr 04, 2009 | Dell OptiPlex GX260 PC Desktop
I LOST IDE ATAPI
All drivers can be found here: http://support.acer-euro.com/drivers/notebook/as_5050.html
Mar 03, 2009 | Acer Aspire 5050-3242 Notebook
Still needed solution of problem
Go to Control Panel - click on System - Click on Hardware - Click on Device Manager - click on IDE ATA/ATAPI Controller.
Then right click on Primary IDE Chanel - then click on Properties - Then Advance Settings - For the Device 0 in Transfer Mode select DMA if available. Then Click OK.
You can also select DMA for Device 1 too
Feb 09, 2009 | Compaq Presario Notebook
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
Acer Aspire 5050-3242 Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
