Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
Bluetooth NS-BTHDST won't turn on
Alright, in the manual thing it says to turn on headset press and hold multifunction button for more than 3 seconds. It also says to go into pairing mode to press and hold the multifunction button for more than 6 seconds.
It was working fine until today; I press the button for 3 seconds and it instantly goes into pairing mode now for no reason. I tried holding it longer and shorter but nothing works.
I tried to use the headset reset thing but I'm pretty sure it didn't work. I plugged it in and pressed both of the volume buttons but nothing happened so I'm assuming that it did not reset itself.
If you have any suggestions please post em! Thanks in advance!
1- Plug the charger into a power outlet and connect the headset
2- Press the Volume Up and Volume Down buttons at the same time for resetting the device.
To Insignia: Please provide a line covering/linking this problem in Troubleshooting section of the manual, too. I found it in the Resetting section on page 22.
Posted on Oct 10, 2011
How does one turn on a Motorola 537w bluetooth
To power your headset on, press and hold the Multifunction for 3 seconds until LED flashes rapidly.
To turn your headset off after use, press and hold the Multifunction button for 3 seconds until the headset flashes rapidly and turns off.
Hope it helps
Apr 16, 2011 | OEM Systems Motorola Bluetooth Headset ,...
How To turn on the headset bloothoot nokia model bh212
Switch on or off
To switch on, press and hold the
multifunction key for about 2 seconds.
The headset beeps, and the green
indicator light is displayed. The
headset tries to connect to a paired
phone.
To switch off, press and hold the
multifunction key for about 5 seconds.
The headset beeps, and the red
indicator light is briefly displayed.
Pair the headset
1. Ensure that your phone is on and
the headset is off.
2. Press and hold the multifunction
key (for about 5 seconds) until the
green indicator light starts to flash
quickly.
3. Activate the Bluetooth feature on
the phone, and set it to search for
Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair
and connect the headset to your
phone. In some phones, you may
need to make the connection
separately after pairing.
If the pairing is successful, the
headset appears in the phone menu
where you can view the currently
paired Bluetooth devices.
When the headset is connected to
your phone and is ready for use, the
green indicator light flashes slowly
Mar 26, 2011 | Nokia BH-212 Bluetooth Headset
Looking to download the manual for the ns-bthdst
you can find the manual here http://insigniaproducts.com/products/portable-audio/NS-BTHDST.html they have it in 3 languages as well as the driver for this headset.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment 4 thumbs up. thanks and have a great day.
Aug 19, 2010 | Insignia Bluetooth Wireless Headphones...
My lg vx1100 can not find my plantronics 232 explorer and I do not have the instructions anymore.....can anyone help?
The following are for TB-20EL model. But it works in general for plantronics as well. For step 3 make sure your headset is in pairing mode. When you hold the button 6-8 sec, it should turn either solid blue or blink.
for tb-20el:
1. ensure that your phone's bluetooth feature is on
2.Ensure that the headset is off(press and hold button on your headset (called multifuntcion button) for 2-4 sec, teh indicator light will flash red)
3. press and hold the multifunction button for 6-8 seconds until the indicator light alternately flashes blue and red
4. set your phone to find new device
5. Ente rpin '0000' (four zero) then press OK or yes
6. this should complete the pairing.
Mar 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My samsung wep 301 will not pair with blackberry 8330. In the desktop manager, the check box to enable bluetooth support is greyed out. Windows 7 BB Desktop 5.0.1 Samsung WEP 301 Blackberry 8330 I'll take...
Please rate. This is how we (advisor/problem solvers) get people to know...we know what were doing. Thanx
1.First make sure your phone is off. Do this by pressing and holding the Multifunction button (the one that flashes blue) for 4 seconds. For "OFF" it will flash blue and red along with a series of 2 tones. Then will stop flashing. For turning "ON" hold multifunction button for 4 seconds and it will flash BLUE 4 times and 1 tone indicating it is on. It will continue to flash every 3 while in stand-by mode and every 8 seconds while on a call. 2.Set your phone in "Discover mode" make sure you look at your manual on how this is done if don't know how. Usually found under Bluetooth settings. 3.Making sure your headset if off. Press and hold the Multi-Function button until the indicator light turns solid blue (hold for approximately 8 seconds). THE MULTIFUNCTION BUTTON WILL BE LITE ONLY HALF BLUE INDICATING PAIRING MODE. 4. You phone will find and ask to pair. Press confirm/OK and enter "0000" 5.If pairing successful, light will flash blue 10x rapidly before going to flash every 3 seconds. IF UNSUCCESSFUL LIGHT WILL REMAIN ON, AND YOU WILL HAVE TO RE-ATTEMPT.
Jan 15, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
I need to get my manuals for my NS-BTHDST
http://insigniaproducts.com/cms/documents/NS-BTHDP_NS-BTHDST UM EN_SP_FR.pdf
Jun 25, 2009 | Insignia Bluetooth Wireless Headphones...
Where?
power button is the little nipple between the phone and play/pause pictures on right side. You hold down for 2 seconds until blue light comes on to turn on.
Too shut off hold down button 4 until red light comes on.
if want too pair with device hold button down 6 seconds until light blinks blue red
pass code is 0000
May 15, 2009 | Insignia Bluetooth Wireless Headphones...
Need passkey to connect my tb20el bluetooth to my phone
for tb-20el:
Apr 14, 2009 | Motorola Mobility H700 Wireless Headset
How do you pair your Insignia Headphones/ Headset with a PS3? It is called an insignia NS-BTHDP/NS-BTHDST. In the instructions it only talks about pairing it with a computer. Can someone help me?
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
Mar 26, 2009 | Insignia Bluetooth Wireless Headphones...
Won't charge or turn on.
I wrote to Insignia and they recommended the following procedure, which worked for me:
My earphones are working well now.
Regards,
Celso
Aug 26, 2008 | Insignia Bluetooth Wireless...
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
803 people viewed this question
Top Insignia Radio Communications Experts
Skyken
Level 1 Expert
woodzowl307
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
