I HAVE LOST MY IDE ATAPI CONTROLLER FOR MY ASPIRE 5050,IF I FORMAT MY HARD DRIVE WILL I BE ABLE TO REINSTALL XP IN MY LAPTOP,AND WHERE CAN I GET FREE DRIVES FOR ASPIRE 5050
The only time I have problems as you you describe it's because the movie isn't streaming fast enough to maintain a steady viewing experience - nothing to do with your drive interface.
To reinstall the IDE controller, go into Device Manager (right click my computer and select properties). You should see IDE ATA/ATAPI controllers. Click on the little + sign and you'll see a list of controllers. Right click each in turn and uninstall. When you've done that, restart the pc and it'll reinstall them automatically.
General Features: 10.2 GB formatted capacity UDMA/66 7200 RPM spindle speed 2 MB buffer 9.0 ms average access time 4.17 ms average latency E-IDE/ATAPI interface 3.5-inch form factor
Notes: Drive only Maxtor model #: 51024U2
Additional Information:
Product Requirements
IDE controller IDE cable Available 3.5-inch drive bay Available 4-pin power connector
Try one of these: 1. http://support.microsoft.com/kb/314060 or... 2. http://aumha.org/downloads/cdgone.zip or... 3. Go to Device Manager, click a "+" sign next to IDE ATA/ATAPI Controllers. You'll see two items: - ATA Channel0 (or Primary Channel) - ATA Channel1 (or Secondary Channel) Right click on each of them, and click Uninstal. Confirm. Restart Windows. They'll be automatically reinstalled.
1. Go to Device manager. Click on the + sign beside IDE drives. Right click on the dvd drive and select uninstall. Restart the computer. It should get installed automatically as it is a generic driver.
2. Go to run > type regedit > go to the following key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ Select the folder that says ( 4D36E965..... on the right hand side delete the file that says "Upper filters" and "Lower filters"
3. Go to device manager > clock on the + sign beside IDE ATA ATAPI Controllers > right click on Secondary IDE channel and secect uninstall. Do the same with Primary IDE channel. Restart the computer.
yes you can.but you must have a valid xp product key or it will registerit as an acer and will not proceed.i have done it on alot of acers..you will also have to know all the drivers that are for your 5050.you will have to download them all to a cd, then install them ..in the order u download them and it will work fine..youll like it alot better.you should try to create a second partiton for reovery..steve
Go to Control Panel - click on System - Click on Hardware - Click on Device Manager - click on IDE ATA/ATAPI Controller.
Then right click on Primary IDE Chanel - then click on Properties - Then Advance Settings - For the Device 0 in Transfer Mode select DMA if available. Then Click OK.
You can also select DMA for Device 1 too
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
