Question about Sony Televison & Video
My sony 65 inch projetion tv has a shadowed picture. It looks like it just needs to be adjusted, how do I adjust the picture?
  • Joe1974 May 11, 2010
    I can't help you with just the info provided. Is the shadowing like color separation? I can tell you that the site that Jean posted will not fix this problem. That sight pertains to a specific problem that is common in some Sony sets and should not be used to try to fix any other issue.
    Please keep in mind many things can go wrong with TV
    sets and you should really do a lot of research before attempting any
    adjustment and or repair. There are high voltages present and they can
    reside even when the set is unplugged.
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via the voltage on the
color ray gun tubes that get out of adjustment.
They are also known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Hope the blog helps you also :)
Jean
Posted on Mar 12, 2009
Sony Bravia 52 blurry Picture
Contact the authorized service center for Sony. So many adjustments have to be done after T'Con boar replacement. You can do it, if you are an expert engineer specialized in electronic engineering. If not, please do not make the set irreparable by doing more adjustments that you do not know. OK?
Aug 30, 2012 | Sony Kdl-52vl150 52" HDTV LCD TV
My Samsung HCN653W 65-Inch Widescreen Projection HD-Ready TV has a 3d like picture when it has been on a hour it goes back to normal
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 05, 2011 | Samsung HCN653W 65" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony KDP-65WS550 65 in. Rear Projection HDTV One day turned on
This can be as simple as poor solder connections at the convergence ICs or defective ICs. If you can solder you can fiz this yourself. Let me know if you wish to attempt the repair and I'll suply additional details and instructions.
Dan
Mar 24, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Sony kp-48s75, shadow or ghosting picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 07, 2009 | Sony KP-48S75 48" Rear Projection...
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Televison & Video Logo
221 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
