Question about Car Audio & Video
No power I have a clarion Marine Cd Stereo #M3170 I bought it a few years ago and never got around to hooking it up in my Boat. Now I decided to install it in another Boat and after trying to hook it up it won,t even light up. It acts as if there is No power hooked to it. It was stored in a Cabinet in my garage and was never used.
  • jwatermkgril Mar 03, 2009
    i have a sony dsx L 350. It's on a boat. The lights flash on and off, and sometimes nothing. Could it be a ground problem.
Do you have the manual. I have the same model installed on my BMW 1100RT motorcycle and it requires two power hookups. One senses the ignition is turned on and the other is the power up from power source. If the ignition power wire isn't connected, the unit will not powerup. You can however, connect both of these power wires to bypass the ignition switch. This ignition switch is used so you don't kill your batter by accident. I'm sure that wouldn't be good on a boat. Good luck!
Posted on Apr 04, 2009
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
I have taken the head unit out of my old boat, would like a wiring daiagram, to installin my new boat!
Red = switched power
black = ground (earth)
yellow = bat power (on)
blue white striped antenna turn on
solid blue remote turn on for amp
(speakers)
(all will have one with black/white stripe if all sets have black = ground if all sets white = hot/+
green = rear
( cant remember left/right)
purple = rear
white = left front
Red = Right front
all of this should be on the bottom of the stereo
Dec 14, 2010 | Clarion M255 AM/FM Marine CD Player
I have a clarion m455a marine raidio in our new boat. It has two cmrc3d remote control stations. niether one of them work. Why
Sorry I can't help you...but wanted to let you know you are not alone. I bought a 2007 Chap last March and have the same problem. I've covered all the basic/common sense troubleshooting but can't get them to function. My frustration is that the displays work so the clock/radio station is displayed but nothing in regards to controlling the deck.
Aug 08, 2010 | Clarion M455a Marine Cd Receiver
My sirius reciever in my boat worked fine until this year now it wont work antenna is only two years old and it is a high quality marine antenna could it be the reciever it is hooked to a clarion radio...
Oxidation from humidity could have tarnished a connector somewhere. Make sure all connectors are clean and shiny first. It could be that the receiver is bad. A stereo shop should be able to check that for you easily.
Mar 13, 2010 | Clarion (NAVSIR) SIRIUS Radio Receiver
My new Clarion CMD6 stereo won't stay powered up.
If all power and ground are good to go then the unit needs to be fixed. Being that it is more likely to "see" moisture, it may have water shorting out the circuits.
Jul 03, 2009 | Car Audio & Video
Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Jul 30, 2007 | iLO XM-MP3-CD Car Stereo
Clarion Xmd3
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Jun 26, 2007 | Clarion XMD3
Car Audio & Video Logo
364 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
