Back to:
Tags:
Intel PWLA8490XTL/5PKINTEL Pro 1000XT Server Adapter 10/100/1000  Network Adapter
Boot Problems - Intel PRO 1000XT
By Reynolds - usenet poster
Hi
I have just purchased the OpenBSD 3.1 CD and am attempting to install it
onto a Dell PowerEdge 1650.
The Dell has 2 x Embedded Intel PRO 1000XT (82544EI) NIC's.
However, the system hangs whem booting from the CD at the same point every
time with the following output:
There is also an Intel PRO 100 NIC that it seems to be happy with.
When I disable the 2 Intel PRO 1000XT's the system boots fine and allows
configuration of the single PRO 100.
If I disable just one of the 1000TX'x, the same error message as above
appears, just with "pci1".
I hope this is enough information and that somebody out there has a solution
to this problem.
Any help would be greatly appreciated.
Regards
Jonathan Liversidge
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Ross
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i had the same problem. it's been fixed in current so installing a
snapshot should fix tour problem. it was a problem with pchb.
the original thread was
and the file needed to be fixed is:
there have been other changes made in current that will help other
hardware in that box, so i reccomend you install current.
-f
p.s. - a full dmesg (even with gx devices disabled) would have been
necessary to diagnose the problem. i'm assuming the problem is the same
as mine given your hardware description, but a full dmesg would have
verified you had pchb giving errors as well.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Boot Problems - Intel PRO 1000XT:
I don't want to Accept this solution
Can you Help with these Network Adapters problems?
Network Adapters
Gde mogu da update nadjem za ovaj proizvod
Network Adapters
In the device manager ISATAP driver is shown with yello...
Network Adapters
cuased by realtek 8101/8168/8169 pcie adapter...
Network Adapters
i tried to install a webcam on my laptop and now it isn't...
Network Adapters
Hi there, im after plans to make a new pop top roof for an...
Loading problems.
Repair Service
Find Network Adapter Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
