Print job is sent to printer. Printer starts up and cartridge holder moves to start printing but then nothing happens. Power light just keeps flashing. I can get it to print a self-test page and a different error number shows up each time. so far error codes are: 905D0001, 905DA302, 60000077
How to use the solutions in this document
To resolve the issue, try each solution
in this document, and then use the steps in this section to print a
self-test report. This step determines if the product hardware functions
correctly. When you have resolved the issue, and the product
successfully prints a self-test report, there is no need to continue
troubleshooting.
Print a self-test page
Follow these steps to print a self-test report.
IMPORTANT
: Try to print a self-test report after every solution even if the solution resolves the issue.
SOURCE: Flashing Lights on HP 690C - Won't Print
Hi Stev, First I know this is going to sound strange but have you disconnected the printer cable from the printer itself? (not the computer) If not try unplugging both the parallel and power cables for 30 seconds, then when you reconnect and power up hit the resume button. I've seen problems in the past where a job was killed like that and the printer would not work until the parallel cable was removed from the printer. The light pattern you describe, resume light blinking with the power light on, can mean any one of the following things on that model HP. 1. Top cover is open. Open the top and make sure there is nothing keeping the cover from closing all the way. Don't forget to check the underside of the cover for something stuck to it. Close the top cover. 2. A print cartridge is missing or an incorrect print cartridge is installed. Install the correct print cartridge. AND/OR Verify that the print cartridge is properly snapped into place. Close the top cover. 3. Printer detects an out-of-media condition. Load media in the lower (IN) tray and press the Resume button. 4. Media is improperly loaded. Remove media from the IN tray, re-square the stack, and reload. Make sure that the media-width adjuster and media-length adjuster are against the stack of media. Make sure that media is not buckled in the IN tray. Verify that the media-width adjuster is along the left edge of the tray and is pushing the right edge of the media against the right wall. 5. The printer timed out waiting for a form-feed command. Press the Resume button. The page will eject from the upper (OUT) tray. 6. Printer detects out-of-ink condition. Replace the print cartridge and press the Resume button. 7. Dirty Cartridge Contacts Use a clean foam-rubber swab or lint-free cloth slightly dampened with water. (Distilled water is recommended. Tap water might contain contaminates that could damage the cartridge.) Locate the copper-colored circuitry strip on the back of the cartridge. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. Unplug the power cord from the printer. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or lint-free cloth to remove the moisture from the contacts. If the carriage contacts show noticeable damage, contact the HP Customer Support Center listed in the printer's User's Guide. Plug the printer back in and try printing again. 8. Printer detects paper in the paper path. Turn the printer off and open the top cover. Make sure that paper is not jammed in the printer. Lift the right black rectangular paper sensor (located in the middle of the printer just below the silver rod on which the cartridge carriage slides) and make sure that nothing is stuck under the paper sensor, perhaps by blowing under the sensor. Close the top cover and turn the printer on. Try printing again. If none of this helps let me know and I'll see what else I can dig up on the problem. El Duderino
SOURCE: Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
SOURCE: ERROR CODE FOR FLASHING LIGHTS
Hi, Kindly remove your carts then replace then again. try this 2 to 3 times repeatedly. Hope This helps ======================= If you are having trouble with Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
SOURCE: My HP Deskjet F4580 won't print. Print jobs go
plaese folloW the instrutoion mention from the below URL and try
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&cc=us&lc=en&dlc=en&product=3944758
still dose not work then try this url mention from the bellow
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669384&cc=us&lc=en&dlc=en&product=3944758
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&cc=us&lc=en&dlc=en&product=3944758
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01361419&cc=us&lc=en&dlc=en&product=3944758
if still the issue is not resolve then contact hp tollfree number 1800-474-6836 they will replaced the printer if the warranty period is there.
hope this should resolve your problem
thanks
regards
HAMID
