Question about Vehicle Parts & Accessories
WHERE CAN I FIND THE PUSH BUTTON SWITCH TO GET OUT OF THE VALET MODE
    Sergeant:
  • 270 Answers
It is on the dash board near the security system
Posted on Mar 03, 2009
Car starter in valet mode
  1. 1 Insert the key into the ignition.
  2. 2 Turn the ignition switch to "ON." Do not start the engine.
  3. 3 Press and hold the valet/override button within five seconds of turning the ignition on. The valet button is located beneath the steering column.
  4. 4 Release the valet/override button after the security indicator light turns off.
  5. 5 Turn the ignition switch off.
Dec 07, 2013 | Dodge Cars & Trucks
Where is the valet switch on my remote controller
The K9-Eclipse has a push button valet switch. The switch is about 1/2" in diameter and about 3/8" in height. I can be installed anywhere but it is usually under the dash.
In order to activate valet mode, you need to push and hold the button for 3 seconds while the system is disarmed. Valet mode will be confirmed with a long siren chirp and the LED illuminating.
Valet mode can be deactivated by pushing and releasing the button.
Sep 23, 2012 | Excalibur. K9-ECLIPSE 2-Way Keyless Entry...
Need to know how or get instruction to program new auto page xt-100 oled remote starter.
REMOTE TRANSMITTER PROGRAMMING Enter: 1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in ON position. Within 15 seconds. 2. Push the Valet switch 2 times and hold in on the 2 nd push, when a long chirp is heard then release the valet switch. You are now in the Transmitter programming mode. Program: 1. Press the Lock button on transmitter 1 until the siren responds on Car with a confirming chirp; the first transmitter is now programmed to Car. Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps will confirm exit. Note: If more than 4 transmitters programmed, the system will only keep the last four. The Valet switch is a little Red Push Button that should be mounted under the lower left side of you dash or in the lower left kick panel near the E-brake pedal.
http://www.autopageusa.com/resources/2%20Push%20transmitter%20PROGRAMMING13.pdf
This sis atndard programming for the 900,915,1000,and 100 units.
Feb 12, 2011 | RS1000 OLED 2Way OLED Remote Start w 6...
Recharged car battery and now remote will not start but it open and closed the locks
Sounds like it may be in valet mode. What brand and model security system do you have?
Most systems, require that the ignition be on and than you activate the valet switch that is installed in your vehicle. The switch can be a push button switch or a toggle switch.
Nov 14, 2010 | Honda Vehicle Parts & Accessories
Can you reprogram a 1996 Suzuki Sidekick remote?
For a 94-97 single button remote:
- Flip Valet switch to ON position
- With key in ignition, turn key to ON, then OFF
- Flip the valet switch to OFF, then ON/OFF, ON/OFF (that's twice), and you should hear a confirmation siren chirp.
- Turn the ignition switch On/OFF, ON/OFF (twice), and you should get another confirmation chirp.
- You are now in programming mode. Push button on the remote, and you should hear a chirp to confirm programming completed successfully.
- After 5 seconds, the programming mode will close automatically.
Good Luck and please rate 4thumbs up for the free answer and also please leave a Testimonial Thank You.
Oct 02, 2010 | 1996 Suzuki Sidekick
Program remote
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
2. Push the Valet switch 2 times and hold in on the 2nd
Program:
Jul 09, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
How to re program my pager? (autopage 1000
Enter:
Program:
Jun 03, 2010 | RS1000 OLED 2Way OLED Remote Start w 6...
How do I get the car alarm out of valet mode?
leave a door open then turn ignition on then off and push the valet switch one time within 10sec
May 23, 2010 | 426P 460HP Security System - 426P
HOW DO I DISARM RATTLER ALARM ON MY SATURN L100 IT WONT START SOMETIMES LIGHT KEEPS FLASHING INSIDE I JUST BOUGHT CAR USED 56000MILESD ON IT ITS DRIVING ME CRAZY I DONT KNOW IF IS FACTORY OR NOT
This car does not come with that equipment as factory option. You may wish to put the alarm in "valet" mode. There should be an override/valet button or switch mounted somewhere under the lower dash panel. With the key in the "run" position, push the valet button, and the little red "LED" light should light solid, verifying it's in valet mode, and will not arm, but keyless entry functions will still work.
May 05, 2009 | Vehicle Parts & Accessories
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
353 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
