Question about Gateway MX6027 PC Notebook
I have Gateway MX6027 laptop. My ac adapter get real hot. i went through 2 chargers in the last 2 months. I am wondering if I got a short on the motherboard, or maybe if there is a voltage regulator that is bad.
  • David Shaub May 11, 2010
    Stand the adaptor on it's side. If you have it on a carpet, it won't get proper air flow. It should be used on a hard surface.
  • 46 Answers
Does the AC adapter get hot if you use it to power the notebook with the main battery removed? If not, the battery or internal charging board may be faulty/
Posted on Mar 04, 2009
Gateway ma2 mx6027 not turning on help?
Find another charger and try again! You may have a dead battery and can't get the unit to work because the charge is bad.
Nov 25, 2013 | Gateway MA2 MX6025, MX6027, MX6028 Laptop...
Gateway laptop won't come on
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Nov 04, 2012 | Gateway MX6027 PC Notebook
I have a Toshiba Satelite A45-S151 and my original AC adapter fried the rubber around its cables so i bought a new one but after one day of use the new adapter stopped working and i had gotten a...
It sounds like there is a short in the computer or in the battery. Exchange the charger wherever you got it from, take the battery out and try the new charger and see if it will last a week without getting too hot. That will tell you if its the battery or the plug inside the computer.
Jun 10, 2011 | Toshiba Satellite A45-S151 Notebook
My Gateway NV5386u battery died and the computer shutdown. When I tried plugging it in, it still would not turn on. The adapter part of the charger has a green light, indicating power is being applied, but...
Often when a battery is real flat, it hangs up the entire system. What you need to do, is remove the battery completely, as the laptop should be able to be powered by the AC adapter itself. You may find if that is the case that your battery has gone bad, and you will have to replace it. If your laptop, will NOT work from the AC adapter, then either the adapter is faulty, or there is an internal vault, in the Power conditioning circuitry inside the PC. Try another adapter, if still no go, then it is definitely an internal problem.
Jul 16, 2010 | Gateway NV5386u 156Inch Laptop (Blue) PC...
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Inspiron 1720 is shorting ac adapter? laptop has
It can be the AC power jack on your laptop. Believe me I have an inspiron myself and this problem is a real pain. However you can easily fix it by un-soldering the old jack, re-soldering the new one in. You can find a replacement on e-bay. If you are not good at soldering,I suggest you take professional assistance. Its a very inexpensive repair.
Oct 24, 2009 | Dell Inspiron 1720 Notebook
Hp compaq nc6320 doesnt charge
i thibk the charger head went out thats what happend to my gateway just cut the part of the charger that goes into the computer (if its not the prob u can fix it back later) cut it open and see if any of the wire has broke off if so use a soutering iron (i dont know how to sourtering)
and some souter and souter it back on thats the best i can help
ps i done this to my gateway labtop and it worked fine
Oct 02, 2009 | HP Compaq nc6320 Notebook
My hp 6715s laptop wrecks chargers, im on the 6th
2 possibilities
Either unstable AC current in the house (Generally, other items that have AC adapters would be failing too)
Motherboard charging Circuit issue (Motherboard replacement)
Sep 14, 2009 | Computers & Internet
Charger not recognized
The issue with most of the Dell charger issues rekated to a new charger not being able to charge the battery is the fact that Dell has a screwy proprietary circuit design in their laptops and chargers.
It seems that the Dell laptops are designed so
only Dell chargers will work. While other
brands of chargers will power the laptop when plugged in,
they will not charge the battery.
They do this so they have a monopoly on their chargers and thus can charge a frickin' fortune for their, Dell chargers.
Want them to change this? don't buy Dell products for a while. If enough people ban them, they would change this **** overnight!
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Gateway MX6027 PC Notebook Logo
153 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
