Question about Galaxy Radios DX-949 40-Channels Base CB Radio
Galaxy 949 mobile CB is off frequency when
Galaxy 949 mobile is off frequency when transmitting. how do I adjust it?
  • va3get Mar 04, 2009
    cannot find adjustment procedures for galaxy 2517
    Problem Solver:
  • 6 Answers
A friend of mine just told me he used the galaxy 2517 adjustment procedures. I hope this may help you. Buckeye back quiet.
Posted on Mar 04, 2009
Tip
Galaxy DX 959 CB radio no transmit or talkback
Hi, I have a problem with this CB radio. The PA works good but after installing the MOSFET kit as mentioned here http://cgi.ebay.com/DUAL-POWER-TRANSISTOR-MOD-KIT-GALAXY-949-959_W0QQitemZ190256621565QQcmdZViewItem?hash=item190256621565&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 it wont transmit and I cant hear myself on talkback nor do I hear the roger beep. The PA amp works though.
on Oct 15, 2008 | Galaxy Radios DX-959 40-Channels Base CB...
My galaxy 949 will not transmit on sidebandwhy is that
There are too many possibilities as to what the fix is for your radio. You need to take your radio into a radio shop that services CB radios.
Oct 19, 2014 | Galaxy Radios DX-949 40-Channels Base CB...
Galaxy dx 2547 base cb frequency drift problems
for upper ssb adjust L21 for 16.51250 mhz . adjust L22 for 16.50750 for lower ssb. you do have a frequency counter don't you ?
Jan 01, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
Got a galaxy dx 949 mobile trying to wire a older d-104 to it and it dosent sound right its not got the mod it needs. thanks
Hello twelch,
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
If it is the old four(4) wire mic, the wiring will be as follows:
Pin #1. Shield (Ground)
Pin #2. White (Audio)
Pin #3. Red (Transmit)
Pin #4. Black (Recieve)
If it is a SIX (6) wire! The Blue would go to Pin #1. with the Shield, and the Yellow
has no connection. I hope this was helpful to you. Your Comments and Testimony's are
always welcome here at FixYa. Thanks for choosing FixYa today and in the future.
John
Feb 27, 2011 | Galaxy Radios DX-949 40-Channels Base CB...
Finals shot? picked up a galaxy 949 and it does not transmit, if i replace the two finals or transistors what elnse needs to be done?
just follow service manual make sure its aligned properly .. some of those radios have pll problems too causing them not to TX...
Feb 07, 2011 | Galaxy Radios DX-949 40-Channels Base CB...
29 LTD classic recieve is way off frequency. recieve sounds like bleed over from another channel. how do i adjust the receive frquency for a cobra 29 ltd classic?
un fortunatly to properly align this radio you need an audio VTVM, occiliscope and a dummy load.
but before you get crazy with trying to align your radio, is the delta tune right in the middle? if not thats why recieve is off.... as well you can adjust delta tune to compensate for off frequency.
Jan 04, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
It transmits off frequency is there a adjustment and also the frequency counter goes crazy at times
To add 10Khz to your transmit frequency:
FIXED/OFF/+10KHz SWITCH:
The left position puts the radio on
one of the three fixed channels that is selected by the channel switch
(6,19, or 21). This over-rides the channel selected by the 40 channel
knob. The right position adds 10KHz to whatever frequency you are ON.
In the middle, both features are OFF.
Otherwise, a radio tech would be able to retune the frequency inside the radio.
After adding 10KHz to your frequency, use the SWR control to check the SWR of your antenna.
Here's how:
SWR CAL CONTROL: Normally this switch is set to “PO”. Then,
during transmission, the meter indicates output power. To read SWR,
rotate this knob during transmission until the needle moves to the “SET”
point on the SWR scale. Then, while still transmitting, set the R.B./SWR
switch to SWR.
Ideal SWR is 1 but you'll want to be as near one as possible. An SWR of 1.6 or greater will make ineffective use of your antenna.
If in doubt, a radio tech has the required meters and tools to adjust the SWR/Tuning of your antenna.
May 10, 2009 | Galaxy Radios DX-73V 40-Channels Base CB...
Powers up, recieves fine, breaksup on transmit Galaxy 949
Check the wiring on the mic plug sounds like you have a loose wire or one thats about to break off.Good luck.....Dan
Apr 01, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Galaxy 959 transmit off frequency 27.186
The transmit frequency on the DX959 is adjusted with VR-7.
Nov 11, 2008 | Radio Communications
Galaxy Radios DX-949 40-Channels Base CB Radio Logo
375 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
