Question about Ingersoll Rand Compressors 5-HP, 80-Gallon, Triple Stage Rota
ROTARY SCREW COMPRESSOR TRIPPING
Sirs, My Inger soll Rand made rotary screw compressor (oil lubricated type) tripped without any significant reason. Within 10 minutes the operator started the compressor, andit tripped again showing high load on the motor. What could be the reason? kindly help
    Guru:
  • 462 Answers
Possibly water in the air tank ? Or Ice covering the inlet or screen into the tank? DOes it have a belt? or direct drive? Remove the belt and try to turn by hand. See if its the motor or the compressor is tight. If it rolls free possible a chack valve is hung up or has a broken spring OR yuo have a bad capicator or centrifical sw going to the start capicator. Check amp draw with no pressure on the compressor. tank open. If it runs extra time its somethign while under load. If it still cuts out you need to sepperate and discover if its a mechanical or electrical problem.
HOPE THIS HELPS PLEASE RATE ME ACCORDINGLY AND GOOD LUCK
Posted on Mar 03, 2009
  • Farley Redfield
    Farley Redfield Mar 03, 2009
    OH I see another possibility. You ahave lost one of your stages. U say its 3 stage and turns faster than normal... the stages aer where the air leaves i area and enters the next and is compressed futher then the 2nd area and is compressed to the 3rd. One of the stages (I suspect a gasket or valve or a spring operating one stage or 2 is open. Suspecting the 2nd stage as it could allow a faster speed at startup then as the unit continues to run too long from not reaching the cut off pressure it ober loads. IF THIS HELPS PLEASE GRADE ME ACCORDINGLY and good luck.
2nd stage high pressure alarm is coming and the compressor is tripping. can you pl suggest
I will need more info on this. What is the model of compressor. Is it oil free or a 2 stage oil flooded. From the info provided it sounds like an oil free unit. These units have alarms for 1st and 2nd stages. Suggest inspecting the discharge check valve with out more info.
Feb 14, 2011 | Ingersoll Rand Stationary Air Cooled...
HAVE A SSR-XH60 SCREW COMPRESSOR WITH 39180419 INTELLISYS CONTROL KIT AND IT SHOWS "STARTER FAULT" WHAT THIS MESSAGE MEANS?
The motor starter overload auxiliary contact is wired into the intellisys control unit. If the motor would overload, then the thermal overloads in the motor starter will trip. When this occurs you will get that message. The overloads are in the electric panel on the left side. You will have to remove the screws to gain access. Be sure to have disconnect off when removing cover. There is a reset button on the motor starter you can press to reset. Now the question is why did it trip? There are a few common possibilities. On is dirt in the coil not allowing enough air to pass over the motor. Slipping belt generating too much heat. Old or low oil causing high temperatures. Pressure setting set higher than unit is designed. You can set pressure on the intellisys. Another reason is short cycling. If you have this set for start stop operation by pressure, the minimum run time should be at least 10 min, and I believe mfg recommends even longer. If it starts and stops too frequently, the motor will overheat.I hope this helps. (I maintain a very similar unit where I work) These units are usually very trouble free units if you keep the oil, oil filter, air filter, and separator changed as recommended.
Oct 19, 2010 | Ingersoll Rand Stationary Air Cooled...
My ingersoll ssr2000 rotary screw compressor trips &restart on it
Check defective HATS or Airend is defective. HATS means High Airend Temperature Switch.
Mar 03, 2010 | Ingersoll Rand Stationary Air Cooled...
My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Aug 08, 2009 | Ingersoll Rand - Rand Type - 30...
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Ingersoll Rand Compressors  5-HP, 80-Gallon, Triple Stage Rota Logo
387 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
