Question about SmartDisk FireLite 80 GB Hard Drive
When I plug in the drive to my MacBook Pro it shows up and does the backup, but no data is actually backed up. Is it something with the firelite?
This is the only advice I can find:
http://www.verbatim.com/support/support.cfm?open=FAQ
Posted on Feb 01, 2010
It seems the new macbook pro does not support the firewire connector. Is there a different wire available? It looks like the macbook pro has a firewire connection but it is much smaller than the original...
The problem lies in your cable!
The new macbook pro still uses firewire and will be compatable with your drive. It just uses a 4-pin instead of a 6-pin connector. You can get an adapter or new cable that goes from 6 to 4-pins.
They did take away firewire from the new line of plain macbooks though (shakes fist at steve jobs)
Feb 07, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
My MacBook Pro no longer reads this portable hard drive. I have tried to plug it into a different MacBook Pro and the hard drive mounted onto the this laptop. I tried to transfer the files to a different...
at this point it sounds as though the drive itself is corrupted It is very difficult to try to get the data off once this happens and so there are data recovery places which charge into the thousands to do this.
Jan 21, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
How to backup your computer onto a firelite hard drive
VISTA: Hit the flag and go to computer. You should see the hard drive then if it is plugged in.
XP: Hit start and go to my computer and you should see the hard drive then if it is plugged in.
If this doesn't work try another USB slot for the dard drive. Some of your USB slots may be defective.
Oct 18, 2009 | FireLite (USBFLB80) Hard Drive
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
My SmartDisk 80 gb FireLite hard drive says it is full but it is empty. What could be the reason for this and how would I format it? I use a Macbook pro. I dont want to have to buy a new external...
You will receive an error message when copying a file larger than 4GB to the hard drive if the drive is formatted FAT32. The FAT32 file system has a file size limitation of 4GB. You may also receive an error when backing up to the hard drive using backup software. To correct this problem you will need to format the drive to NTFS. If you are using Windows ME or 98SE, you will not be able to use NTFS.
There are some products that do not support the NTFS files system or changing their file system. If you own a FlashTrax/FlashTrax XT/FotoChute/PhotoBank/USB FireLite XPress, you cannot change the format of the drive to NTFS. It must be kept as FAT32 in order to operate properly. If you are using SOHO NAS via ethernet, do not format it to NTFS. If you have any questions, please contact technical support before you format the drive.
Warning: Formatting a hard drive erases all data from the drive. Please backup any data prior to formatting the hard drive.
To format to NTFS, open My Computer.
1.Right-click on the Verbatim hard drive, left-click on Format.
2.Select NTFS as the File System.
3.Place a check in Quick Format.
4.Click Start.
Once the format completes, you will be able to copy files larger than 4GB to the hard drive.
Feb 03, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
AUTOMATIC BACKUP TO EXTERNAL HARD DRIVE (FIRELITE)
The first thing that comes to mind is the Firelite has become full and can not accept any more backup data.
Delete the data on the Firelite and try running your backup again. If it works then that was the problem.
The backup software should have a configuration setting somewhere that allows it to automatically delete older data and keep it from filling up.
Nov 11, 2007 | FireLite (USBFLB80) Hard Drive
SmartDisk FireLite 80 GB Hard Drive Logo
114 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
