Question about Yamaha Full-Size Keyboard
Looking for circuit diagrams for yamaha dx21
All voltage rails ok. audio sections "live".......battery was dead.Thanks. Would love to get the circuits....Regards Terry
Have you managed to locate a DX21 service manual yet?? What problem are you experiancing with the 21?? From your request notes you mention 'all audio sections are live', do you mean that you have no audio from the 21?? Most faults i have experienced with the 21 are, failure of the main OPP YM2164 fm chip and associated D/A convertor(YM3102). In some cases YM3102 is ok .When the YM2164 fails, DX21 will boot as normal but no sound whatsoever from the audio out's. YM2164 is the main tone generation ic. Also when YM2164 is replaced, if sounds are reloaded back into the memory areas from ROM and the display reads gibberish in certain memory areas then a ram or rams have failed also. The crunch, Don't expect to get a YM2164 and Associated components easily, these things are very rare. I have seen the YM2164 fetch £35!! Best way around this, if you are eager to repair the synth is to purchase a working YAMAHA FBO1 FM MODULE ,not a popiular module and sell for about £20 - £50 on ebay. You can rip the parts out of the unit and use them in the 21. Sell whats left on EBAY spares or repairs.
The damaged (i believe) is caused by failure in the powersuppy causing voltage rails to 'spike'. What is strange is the cpu stays in tact. Capaitor replacements can cure this problem. I have a complete circuit diagram i can scan and email to you for a small fee for my time if required . email me:- proteus4@blueyonder.co.uk
Posted on Mar 08, 2009
Yamaha Piaggero NP12 all "A" and "Eflat" keys are dead.
If all A & Eb are dead it would point to either a bad connection between the keyboard circuit and the motherboard ( ribbon cable ) or possible diode problems on the keyboard PCB.
Initially open up and check connections are all tight and correct.
Did this just happen or has the keyboard been opened up?
Nov 27, 2016 | Yamaha Music
Finding yamaha psr 450 circuit board with part #28750 DM X7588
The actual part # is WC35550R but is costly! $400.00 from Yamaha.
Nov 14, 2012 | Music
Hilkeys@yahoo.comsir i wanted service manual or circuite diagram for yamaha motif es 6. thanks
Call Yamaha of America and ask for "parts department". They can steer you to person that can supply the service manual on CD rom... They charge a nominal fee... used to be $15...
Jan 18, 2011 | Yamaha Motif Music Production Synthesizer
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Jan 13, 2011 | DIGITECH VOCALIST LIVE 2
Behringer Xenyx 1622FX. Power supply has failed, no +5V rail, other rails are OK, appers to be no input to the regulator. Could do with a circuit diagram. I believe the PSU is used in other mixers.
Suspect a broken circuit trace or broken solder. If they use a 7805 three terminal regulator, check the solder around those pins...
Berhinger does NOT release schematics except to their service facilities... I know... I have tried... I repaair a lot of their stuff and have to trace out the circuits.
Power supply circuits are rather easy except for the switching regulators if they have failed totally.
If only the +5 is dead, you should be only a filter cap and a diode or two away from the problem... Transformer leads and electrolytic leads with their weight are favorite to pull out of solder... On Behringer, often the traces are narrow and can have a crack in them.
Jan 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How do i make daw's program program change messages with a dx-21. or must i buy a keyboard controller.Im using Intel. Pen. 3 with 2.2 ghz win. xp v5.1.2600, e-mu dsp audio processor (wdm). software bundle...
ALWAYS to answer your question, refer to the "MIDI IMPLEMENTATION CHART" for your MIDI instrument.
This chart can be found USUALLY near the end of your user's manual.
This chart, among other things, will tell what can be transmitted and received by the MIDI device.
Refering to the chart for your DX21 it shows that the DX21 can both receive and transmit program changes.
If you don't have a user manual, download one here:
http://www.maths.abdn.ac.uk/~bensondj/dx7/manuals/dx21-man.pdf
Nov 09, 2009 | Yamaha Music
Yamaha SY77 Keyboard--getting no power at all. Opened it up and used multimeter to test switch, and all fuses that share the circuit board with the switch. Any flowchart for troubleshooting this? Thanks!
Try looking for the voltage rectifier or bridge diode that converts the A.C. supply into D.C. to power the circuits. Test it with your multimeter using the diode test function if you have one.Hope this helps.
Aug 19, 2009 | Yamaha Music
Yamaha CVP 309-When I power it up, red power light comes on, but
You have to remember that the voltages coming out of the power transformer are A.C. and the voltages used by the devices in the keyboard are D.C. Check for voltage rectifier I.C.s between the transformer and the rtest of the circuits. They should look like squares with 3 pins coming out of the bottom of them and metal backs that protrude above the top of the black squares. Use a volt ohm meter on direct current range and clip the black lead to a circuit ground such as a ground on an output jack. Touch each pin one at a time taking note of the voltage. If you find one that has the same voltage on all 3 pins it is probably shorted. I think the voltage should be about 12volts direct current positive or negative depending on the circuit. Each one will have a code that you can cross reference on the net to find the pinouts and specs. The same thing goes for all the I.C.s If you can find the pinouts for any that you suspect look for the power supply pins and check what the voltage is. Some will have two supplies, one negative and the other positive. If you find an I.C. with power at all pins or ones that should have no power only signal then it is likely shorted. Go slowly and don't bridge two pins at once by accident and you might be able to find the problem without the schematic or a service manual. There is a memory battery (CR2032) that power the memory that might be dead but that should only affect the programmed sounds not the LED or the amp chip. Hope this helps. Do not measure A.C. with the D.C. range or you'll burn out your meter. Use safety precautions with a live device.
Aug 10, 2009 | Music
Casio CT-670 Tone Bank keyboard completely dead
How familiar are you with schematics? I've just found my CT-670, There where marker marks on the keys. I cleaned it up. I took it apart as one channels had no sound. I love this machine. I want to find a manual for it also schematics would be very helpful for me too.
I would suggest looking inside for burns on semiconductors. or loose soldering. I need to replace a chip that has no cross reference... that I've found yet... I think it's an amplifier but need to spend more time on it....
Mar 14, 2009 | Casio Music
Yamaha PSR-280 : AC power instead of DC power
An answer, but likely not a solution. I believe all Yamaha PSR series keyboards use the same 12 VDC adaptor, so I looked at the electrical schematic for another model I have. There seems to be no fuse on the power input. There are two components shown on the positive and negative wires off the power socket, but the symbols do not look like anything I have seen for fuses - they may be resistors. Power goes directly to a 5 VDC voltage regulator, which powers all of the solid state componenents. Too much voltage of the wrong type could have easily ruined many of the sensitive components.
Your only hope is to check the power socket area for the possibility of having fuses. My drawing shows the power socket, voltage regulator, and audio power amplifier being on one circuit board. That may not actually be the way it is in your model.
(your English is fine)
Feb 23, 2009 | Yamaha Portable Keyboard with 61...
Yamaha Full-Size Keyboard Logo
880 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
