Question about Cyberhome CH-DVD 300 DVD Player
I have a dish network 625 dvr and need to program remote for vcr dvd tv in second room can you please help me ??
  • 30 Answers
The remote in most cases will not work on a combo set for power and vol.
Posted on Aug 08, 2009
I need to program my URC-4220 ONE FOR ALL remote to operate my new dual dishnetwork dual dvr for tv number 2. Help
tamiwalsh333
With the TV 2 remote, it needs to be a UHF type remote. Since the signal goes through solid objects (walls, etc.), you should check to see if this remote has that capability. I have provided codes you can try to program the remote to the receiver. I hope this helps.
Dish Network
System 0775, 1005, 1505, 1775
Ray Calo
DISH Network
Aug 17, 2009 | DISH Network DVR-625 DTV Receiver /...
Tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Switch Toshiba projection tv to receive input from video-1?
jbrowne_usa
If your DISH remote is programmed to your Toshiba TV, you can press the TV button at the top left of the remote and then release. This will put the remote in TV mode. Press and release the TV/Video button just below the clear TV button. This will cycle through the inputs on your TV. Continue to press and release until you have Video-1 displayed on your TV screen. I hope this helps.
Ray Calo
DISH Network
Jun 14, 2009 | DISH Network DVR-625 DTV Receiver /...
I need to connect my Dish Network 625 DVR to a JVC RX-709VTN surround sound receiver, along with my DVD and VCR. Nobody can help me at Dish Network. Seems they aren't trained to help outside of the DVR. I...
Providing you have enough input ports on the surround run you a red and white audio RCA jack from the receiver out port for TV1 and connect to the same colored ports on the satellite in ports on the surround. If you do not have enough ports then you may have to use the in ports on the DVD etc to run the TV through to utilize the surround system. Thanks for using Fix Ya.
Apr 07, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
Tip
DISH Solo DVR VIP612 Limited Mode What is DISH Solo DVR VIP 612 Limited Mode?...
You can program your remote control in Limited Mode to keep from accidentally changing the channel on your TV or VCR and causing a snowy or blue screen.
  • When the remote control is in Limited Mode for TV mode, you will only be able to use POWER, MUTE, and VOLUME functions for your TV.
  • When the remote control is in Limited Mode for VCR mode, you will only be able to use POWER and the VCR functions for your VCR.
Note: Limited Mode is not used with amplifiers (AUX mode).
I hope that helps.
Dish dvr 625 can't get dvd/vcr player to work with tv2..
if you have the coax hooked to the VCR in you will need to change the VCR channel to 22 and leave the TV itself tuned to 3 or 4.. I recommend setting the vcr to 60 or 73 to see if you can get reception on there as that is usually the two channels that TV2 is modulated on. You can check the modulation by going to TV1 and pressing menu-6-1-5 on the TV1 remote. Thanks for using Fix Ya. If I can be of further assistance please let me know.
Jan 28, 2009 | DISH Network DVR-625 DTV Receiver /...
How to program my DISH Network remote to my DVD player?
It's kind of silly but I just pushed the VCR mode button, pressed the power on and off mode button & pressed the up button until the remote found the code. Took awhile but it finally worked.
Dec 28, 2008 | DISH Network DVR-625 DTV Receiver /...
Cyberhome CH-DVD 300 DVD Player Logo
52 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
