Question about Cobra 29 LTD CB Radio
Cobra CB gets power, no signal, no noise, no P/A
I have a cobra CB lowest model, 19 i think. i wired to batt. and connected to antenna. nothin. no static, no test, no noise. Speaker fried? should i try a different one? am i overlooking something completely obvious?
thanks guys
    Problem Solver:
  • 6 Answers
Will it light up.
Posted on Mar 04, 2009
Cobra 19 ultra iii
Do you or a friend have a SWR/Power Meter? If the Standing Wave Ratio of the antenna and feedline is to high you will not get the power from the radio to the antenna. You want you SWR to be 1.3 to get a good signal from your antenna. Most antenna have a set screw that is loosened and tightened after either lengthening or shortening the antenna stub.
Apr 09, 2014 | Radio Communications
My cobra 18 wx st comes on and goes tru all channels but has no noise at all coming thru it. none of the signal strength lights come on or anything. its brand new.
Sounds like a antenna issue. Make sure coax is in good order.and antenna is connected properly. You might have to get a "swr" meter to put in line between radio and antenna to make sure antenna is "tuned" to were the radio is operating. Radio shack sells a ok low budget swr/power meter.
Nov 09, 2012 | Cobra 18 WX ST 40-Channels Base CB Radio
2 out of 5 signal reading on cobra cb radio
You'll need to find another CB radio for someone to check to see if they are receiving your transmission.
Aug 16, 2012 | Cobra 19 DX IV CB Radio
WERE CAN I FIND A POWER ADAPTER AND ANTENNA FOR A 200 GTL DX NW COBRA RAIO
We can order them Power cables. We have a few antennas instock or can order what you need. with the lowest prices around.
Dec 25, 2010 | Cobra 200 GTL DX 4-Channels Base CB Radio
How to modify a cobra 19 ultra iii cb
find DM1 and clip it. then you will have full modulation.
Mar 18, 2010 | Cobra 19 Ultra II CB Radio
Excessive static equally on all chanels on cb
You should always connect the CB directly to the battery as the accessory socket is full of noise. You also should choose a better antenna as these small glass mounts cannot hear signals well and magnify local noise. AM (CBs) radios naturally pick up noise as it is the nature of AM signals. Use your squelch to lesson this but too much can knock out you reception.
Feb 14, 2010 | Cobra Radio Communications
Cobra radio getting noise from antenna, how to
That post was meant to be the solution, sorry.
Oct 27, 2009 | Cobra 19 DX IV CB Radio
Installed a cobra CB ultra III on a motorcycle
The external speaker jack was not designed for a head set. It has too much power it over loads head set. You need to solder a resistor in line with the negative wire. You will have to experiment to see which value gets the audio just right for the head set you are using.
Jun 13, 2009 | Cobra 19 Ultra II CB Radio
High SWR
the problem is in the antenna cable. the lenth of a antenna cable must be divisable by 3. try replaceing cable with a 18 foot cable that should fix the problem.
Apr 11, 2009 | Cobra 19 DX IV CB Radio
Cobra 19 dx lv
Sounds as though you may have a poor or bad antennas system. I would suggest to check the antenna match ( SWR, Standing Wave Ratio) and if it's good, you might think about a better antenna. Good Luck
Ed
NC Electronic
Mills, Wyoming
Oct 24, 2007 | Cobra 19 DX IV CB Radio
Cobra 29 LTD CB Radio Logo
132 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
