Question about Kenmore 22422 Top Load Washer
Washer inside banging on the sides of the whasher and is loose ?
The inside tumbler is banging into the sides of the washer and the whole inside is loose ?
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Washer bangs from side to side when on spin . Why
Several potential reasons for this:
  1. Unbalanced load;
  2. Washer is not on a concrete subfloor. This may sound a little silly, but washers situated on a wooden subfloor will vibrate the floor below (much like a person jumping up and down in a rising elevator) so they need to be balanced and anchored to the floor to prevent the vibration and banging.
  3. Loose tumbler--make sure it is properly seated on the drive shaft (less common issue);
  4. Bearings worn out in the shaft that extends up into the barrel (the thing into which you load the clothes). This is unlikely unless you your washer is older (maybe 10 years or so) or is used a lot.
Feb 11, 2015 | Washing Machines
GE Profile washer, tumbler out of balance?
Empty, fill with water only run through spin cycle. Replace clothes
do not overload and try to distribute clothes in an even weight pattern over the tub bottom.
Sep 04, 2014 | GE Profile WPRE6100G Top Load Washer
My Kenmore model # 20642 991 leaks water when it spins (mostly with large loads) and the barrel inside seems to be loose or something because it bangs hard against the inside - sounds like the whole...
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub. The banging noise is due to being unbalanced. You may need to replace the balance ring on the top of the drum inside the washer. Watch this Video to see if this is how your machine is acting.
Nov 26, 2010 | Kenmore Washing Machines
Kenmore front laoder washer with loose wash basket
Highly likely that either your bearings or spider arm has gone out, this is no easy fix. You can 'search' above or click on 'troubleshooting' in blue to browse
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Roof Leak
May be the rubber washer has expired. Do check the whasher.
May 15, 2008 | 1999 Toyota RAV4
Washing machine shaking on spin cycle
what is the brand of the washer along with the model nunber
Apr 12, 2008 | Washing Machines
Banging tumbler during spin cycle
Be certain that nothing got under the rubber skirt, pull it back and look /feel under it .
inside the tub are the large wiper arms solid and not come loose.
open the top access panel (3 screws in top rear )
and open the bottom access Panel (3 screws in bottom front)
Dissconnect power .
Look at the springs and arms that attach to the tub are they secure.
is the large stone concreate slabs secure.
move all these items and push at them all secure?
you can run it while open but the bottom has a switch on front right that has to be closed.
look watch listen.
Feb 03, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Water drip into washer, used to gush in. Now water pipes bang, whine
The problem is the 10 cent rubber washer in a shut off valve in your plumbing. The brass screw that holds this washer has corroded and the washer has come loose. It now floats around inside the valve and the water flow can be blocked at one time, whistle, howel and make bangs at another. It could be any valve including the main shut off. You can listen to the pipes but the sound travels, so you are looking for the loudest spot. A new washer and screw could fix it, but sometimes the screw is broken off requiring a new valve stem. Be prepared to replace the whole valve.
Oct 31, 2007 | Maytag Washing Machines
Kenmore 22422 Top Load Washer Logo
71 people viewed this question
Sal De
fordexpert
Robert Rankin
