Question about Technics SL-BD22 Turntable
Turntable rotating slowly or not at all
HELP!!! My 12-year-old turntable was working perfectly until I was using it heavily last week to transfer my old vinyls to CD. After several hours, the turntable started noticeably slowing down, so I stopped to let it "rest". The next day it started out fine until a couple of hours later it started crawling again and the pitch adjustment did not seem to work. When even the resting did not help, I ordered a new belt. Unfortunately that didn't help either - it barely moves at all now. I've spent almost $50 for the belt and a new stylus. It would almost be cheaper to buy a new turntable rather than taking it to have it fixed, but I want to see if it can be fixed first. Thank you! Jackie
I'm wondering where to get the motor for $19.99. couldn't find anything but uk sites that sold it. thanks!
Posted on May 09, 2008
  • 515 Answers
First and foremost, are you sure you installed the correct replacement belt, and installed it correctly? Just ruling out the obvious. Now, if you installed the belt correctly, then the only other thing that could cause this is a bad motor. Not an expensive part, but with labor, it might be cheaper to just buy a new one. Figure the part itself is about You will more than likely be able to remove the cartridge/stylus and use it on your new turntable, just make sure the tonearm is the same style as your existing turntable - P-MOUNT Tonearm. If you buy another belt drive, you might even be able to keep the belt you purchased as a back up - might fit! Here is some part info on your turntable: - Belt - Part #SJY90080-3 - $5.99 - Motor - MOTOR, 4 VDC, .2 WATTS - Part #SDMB5E - $19.99 Labor - 30min This is just to give you an idea of what it would cost to replace the motor. I put the belt part # on there, just so you could verify that you bought the correct part. Hope this helps some. - Justin
Posted on Sep 02, 2007
SOURCE:
LG LMV 1680 ST shows error AC-1 and will not heat. The turntable does not turn either. The exhaust fan still works and the control panel still responds. What does this code mean?
Check the fuse. Also check out the safety switch by the unit door. If not closed when door is closed, no power is applied to either the turntable or the tube.
Aug 22, 2017 | LG Microwave Ovens
Denon auto lp turntable -model dp=29f
Lift the rubber cover off- there should be an opening or two in the metal or plastic turntable platter. Rotate it slowly until you see the motor pulley sticking-up; use a nail file to gently pull the belt from the bottom of the turntable over the pulley. rotate slowly to verify and then put the rubber cover back on. Let me know how it goes. Thanks.
Aug 01, 2014 | Audio Players & Recorders
Microwave turn table quit rotating
With the model number, we may have been able to give you a link to the actual service manual. Without it, we can only give you general answers.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes, then try it again.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
The turntable pad is used to turn it off for cooking without the turntable, then to turn it back on when you do want to use the turntable.You can find links to helpful exploded view diagrams and part ordering help here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Aug 10, 2013 | Microwave Ovens
Turntable runs far too fast
Post model number and make of the turntable.
Feb 28, 2013 | Audio Players & Recorders
Can't play discs
i can send you the manual to fix it
Sep 18, 2012 | Wurlitzer Jukebox 1015 One More Time...
Turntable does not rotate, help!!
Put your ear to the turntable platter in the on mode. If you can hear a motor spinning sound and no rotation you have a slipped or broken belt.
Remove the rubber matt from top of the turntable platter and now while slowly rotating the platter look through cut out in the metal, at one point you will see a motor spindle and a belt. Feel the tension of the belt , it should be wrapped tight round the pulley. bobhifi_13.jpg
Mar 11, 2011 | Crosley CR248 Turntable
My turntable judders when playing a vinyl.I have tried a different drive belt and a different platter,but that has not helped.I am transferring my vinyl to mp3 so I need a solution.The turntable is about 4...
Check the belt path for any foreign material that may be on the pulleys. Without the belt attached, feel for a rough spot(s) while slowly rotating the platter. Same for drive motor. This will often identify the offending part. With a seldom used table, the grease on the table spindle dries out and may need cleaning with a solvent (alcohol) and q-tips. The same for the motor. Then re-lube with a synthetic oil. Be careful that you don't lose any bearings or spacers. This technique has repaired many tt's. Good luck, work slowly and carefully.
Jan 13, 2011 | Numark ttUSB Turntable
Microwave turntable doesn't turn. Everything else
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Nov 28, 2009 | Frigidaire Microwave Ovens
Hi I have an Emerson microwave oven MW8998B. The turn table will not rotate while cooking. The smaller bags of popcorn just burn the bag. Does this need a repairman or can I fix it myself. Also, I am able...
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
May 13, 2009 | Emerson Black Microwave Oven
Technics SL-BD22 Turntable Logo
316 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
