Question about Sony CMT-NE3 CD Shelf System
Won't power on.
I just bought a used CMT-NE3, plugged it in and it won't power on. The LCD display is dark and the standby power light doesn't glow. Power cord is undamage, (yes the electric outlet has juice). Is there a fuse or breaker inside the case that I should check or can be replaced. I tried using the remote, nothing happens.
  • 27 Answers
First, before you grab the screwdriver, check the voltage switch on the back. It should say 110v, not 220v. If it says 220v, just flip it the other way. If that doesn't fix your problem (and you don;t feel like taking it back to the store to be exchanged) then there should be a small fuse inside close to the power transformer inside. Check the fuse. If it's blown, you have your rusty gear. If it's not blown, close everything up all nice and proper and resort to exchanging.
Posted on Mar 03, 2009
What antenna I need for a Sony CMT NE3 mini hi fi,and where can I buy one in what shop please not on the net.
write down the details of the unit and go to places like JAYCAR or other electronic retailers and talk with them as to what you want
Jun 23, 2016 | Sony CMT-NE3 CD Shelf System
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
My sony cmt-nex3 has the standby light flashing, but when i press the on butto, it doesn't turn on
Check the back for speaker wire shorts, next! there may be a short in the audio output chip or surrounding parts in the stereo, this is more suited for a technician to sort out.
Jul 03, 2012 | Sony CMT-NEZ3 Shelf System
LG 32LH30 screen won't power up. Red light at bottom glows hi to low, but no picture. Unplugged and waited overnight, plugged in again, still no picture.
There is a way to tell if you have a bad board, or a bad panel.
1. Make the room dark and turn on the TV. Can you see it light up? If so, does it stay lit or turn right back off?
2. If the panel lights, but you have no picture, I would suspect the T-con. Some units now have the T-con incorporated with the main board, so you will need to check.
3. If you never get any light at all, then I would suspect the power supply.
4. If you only get light for a second or two, then you have a bad panel.
Apr 10, 2012 | LG 32LH30 32 in. LCD HDTV
MY TV WONT GO OFF STANDBY
if you didn't set it it won't go to standby
Sep 27, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
When I try to turn my computer on, it won't do anything. All I see is the gold light blink in the lower left corner.
Hi mcfarlandger,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 12, 2011 | Acer Aspire 5330-2339 Notebook
I have a 1995 Silverado-1500 series and the problem that I have is that power doesn't reach the glow-plugs...
You probably have a blown fuse that powers your glow plugs. If the fuse is blown, the glow plug relay won't energize, or click, causing no power to your glow plugs.
Jun 02, 2011 | 1999 Chevrolet Silverado 1500
Micro hi fi component system sony cmt-ne5 / ne3 I
Hello
Check its sled motor. It is the motor that helps to spin the disc inside. If disc do not spin inside, check the voltage at the terminals of this motor. If it is alright, and comes near to 5VDC, the sled motor is damaged and have to be replaced. OK.
Dec 03, 2009 | Sony CMT-NE5 CD Shelf System
Is their an aux function for a sony cmt-ne3
What if I no longer have the remote?? Is there another way of accessing the MD or "aux"??
Nov 13, 2009 | Sony CMT-NE3 CD Shelf System
Sony CMT-NE3 CD Shelf System Logo
305 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
