Question about Apple iTunes
ITunes recommends reinstall
I have the same problem, where I cannot burn CD/DVD to back-up my iTunes library but am using XP - has anyone found a solution? Any help would be appreciated. This is very frustrating!
    President:
  • 2,653 Answers
THIS works, it's not as bad as it seems, just follow the directions starting from, "Manually delete the registry entries".
Let me know if you still have problems afterwards.
Posted on Mar 03, 2009
I have a super multi GP10 and I don't know how to burn music from my iTunes with it. I can't install the software.
open Itunes in the top left hand corner select file from thdrop down list you will see Library click to open then you should see back up to disk then more options back up entire library to disk
this might be because you have not selected the option to burn an audio cd or your burning software does not support audio burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
May 21, 2011 | LG GP08NU20 DVD±RW Burner
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
How do I transfer my itunes to another computer?
Cucusoft iTunes to iTunes Transfer is an easy to use iTunes utility designed to help you backup/recover/transfer your whole iTunes library and media files. It's a simple way to keep your iTunes in sync everywhere. You can use "iTunes to iTunes Transfer" to backup your own iTunes library or synchronize multiple iTunes on different computers. The backed up library file is pretty easy to transfer to other iTunes, and it's easy to manage. So with this iTunes Transfer software, you can manage your iPod/iPhone/... on different PCs
Transfer photos, music, videos from iPhone iPad iPod to computer or Mac by this software:
http://www.mustsoftware.com/Cucusoft-iPad-iPhone-iPod-to-Computer-Transfer-guide.html
For iphone/ipod/ipad to Mac transfer
Jul 27, 2010 | Apple iTunes
Code 10 no cd/dvd drive found, unable to burn cd?
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Jun 24, 2009 | Apple iTunes
ITunes not able to burn CD's
you already have other cd / dvd burner software on pc / laptop...use it...(can i suggest a better software than itunes for burning..unless you have this already..nero, ashampoo and / or burn4free cd / dvd)...nero has much more to place on the menu of dvd...cd (u can get creative)....this way your new version of itunes will just keep your ipod up to date (no more regs problems)
Jan 04, 2009 | Toshiba Satellite A105 Notebook
CD/dvd drivers missing or malfunctioning
Try uninstalling itunes, restart computer, and then reintall itunes.
Dec 24, 2008 | Toshiba Satellite A105 Notebook
ITunes registry error/CD-DVD not being recognized
I found the solution at Gearsoftware.com
The Audio FIle System (AFS ) driver is not compatible with Windows Vista.
I changed the driver file name as instructed and TaDa...it fixed my problem with itunes and Windows.
Hope this helps you.
Dec 14, 2008 | Apple iTunes
This is what worked for me.....and how I got to be in this problem.
Out of the blue I guess, didn't really notice, my CD drive vanished, no longer appeared in the "My Computer" screen. The solution I found at that time was to delete the upper and lower registry filters. Yeah, that worked, CD drive back. What I was not aware of was that deleting those filters lead to the itunes registry messages that everybody is refering to, along with the inability to burn a CD in Itunes. Uninstall/reinstall was no help.
The solution:
Follow the directions in this link:
http://support.apple.com/kb/TS2372?viewlocale=en_US
Follow it to the letter until step 11. At step 11 (step #'s refering to the XP instructions) it states to delete the lower filter, which I had done previously so it was not present, go on to step 12.
Step 12 says to right click on UpperFilter, which I had also deleted. The trick here is to ADD IT BACK IN!! Do this by right click on the right side of the Regedit screen, select "New", select "Multi-String Value", name it "UpperFilters". Your Regedit window should now look exactly like the picture in the instructions link. Now continue with step 12, modify your new "UpperFilters" by right clicking on it. Since you just added it, there will be no value data to delete so step 14 can be ignored. Enter value data per step 15 & hit enter. Click ok, reboot and you should be good.
I just did this tonight and after rebooting my CD drive was still visible and working, Itunes did not give me any errors when loading & I was able to burn a CD with Itunes.
Good luck, I hope this helps. It was ******* me off and I suspect others as well.
Nov 23, 2008 | Apple iTunes
Apple iTunes Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
