Question about Fisher and Paykel Fisher & Paykel Washer
F & P washing Machine- top loader failing to spin
My F&P machine decides to fail every now and again as it moves into the final spin stage. It basically freezes and beeps. It sounds as though it is trying to spin (makes a whirring sound) but is simply not moving. It can sometimes have water in the tub when this occurs. It can normally be fixed by restarting (although this can take 3 restarts at times) but not this time;(
  • 125 Answers
Tip the machine back and follow the hose from the pump to the diverter valve, it will have 3 hoses and 2 wires going to it. remove the diverter valve and remove any foreign objects from it, also remove the pump and check the hose between the pump and diverter, sometimes a button or etc can get in there and cause an intermittent problem. hope this helps, p.s. no tools required.
Posted on Mar 03, 2009
    Scholar:
  • 106 Answers
You just have to clean out your filter.............
Washing machine will not complete spin cycle, but does complete the agiatation cycles
Have you thought of replacing it with a new front loader?
They save tremendously in water usage. Mine sames me at least $40.00 a month.
Jun 21, 2017 | Whirlpool Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
MODEL WASHER # FTF214OFS2 BLINKING AND BEEPING LIGHTS WONT STOP
Hello Jennifer Brookman - Unfortunately from what you are describing it sounds like the washer is either experiencing a communication error from the control board or wiring failure. Since you have already tried the basic troubleshooting by flipping the household circuit breaker off, do you notice if the door is securely latching? If it is not, then the issue can also lie with a faulty door latch assembly. I suggest contacting a professional for a proper diagnosis and to move forward accurately.
Feb 10, 2013 | Frigidaire FTF2140F Front Load Washer
My Samsung SWT5V9W top loader spins when you turn the power button on. It still spins during the cycle and 'fights' itself to agitate. Would this be a computer issue?
This can be related to a mechanical issue, Check for free movement of the drum and shaft. check the mountings of the motor,check the suspension and finally the level of the machine, use a rubber mat if the machine moves around.
Jan 23, 2013 | Samsung Washing Machines
Hoover 500m top loader washing machine fails to stop at 'OFF'
timer and dont think u can get them any more
Jan 18, 2013 | Washing Machines
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Washer tumbler does not spin in final stage
hi sounds like the gearbox has slipped a cog and stuck that will cause the belt to burn
Nov 01, 2011 | Frigidaire FEX831CS Top Load Stacked...
Hi, i have a toshiba aw1150s washing machine. it was working fine all along, until it reaches the spin stage. it will empty the whole tub of water. when it tries to initiate a spin, it shows E2 and...
check the safety door switch,, its not going to spin unless that switch is working, ( you can by pass it to test it, Jump clip a jumper between the 2 wires ,, if that fixes the problem replace the switch
Jul 14, 2011 | Washing Machines
. Hi.Have a Zanussi DI720
This is a guess but try gently moving it through the cycles by hand a few times, it may just be that the timer mechanism is stuck a bit from age and or disuse. Turning it may help to loosen it up.Be gentle though.
Jun 05, 2011 | Dishwashers
Washing Machines Logo
254 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
