Question about Apple iPod touch
My iPod Touch won't restore - Apple iPod touch
  • 106 Answers
You will need to restore it then.put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for ten seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and restore it from there
Posted on Mar 24, 2009
My iPod touch 4th gen is disabled and won't shut off, what do I do?
The iPod 4G (fourth generation) is easy to restore to factory settings. This may reinstall the software, and it always wipes all music, video and other data from the iPod. Restoring is the most effective way to fix problems with the iPod that haven't been fixed through traditional troubleshooting. You will not be able to retrieve data from your iPod 4G once it's restored, so make sure you back up your information first.
Plug your iPod 4G into your computer with its dock connector USB cable. Install the most recent version of iTunes and open iTunes. Wait a moment for your iPod to appear in the side bar. Click on your iPod in the side bar and select "Restore." A pop-up window will ask if you're sure you want to clear your iPod and restore to factory settings. Click "Continue" and enter your password, if prompted. Leave the iPod untouched and on a flat surface while it restores to original settings. It's important that you don't try to disconnect or use the iPod while it's restoring. You'll see a progress bar either on the iPod or your computer that indicates how far along the process is. Select your new syncing settings (automatic sync or manual) when prompted after the restore is complete.
Feb 10, 2013 | Apple iPod touch
Ipod touch won't stay on
First, there are possibility that your iPod just out of battery, not enough to boot.
You might want to turn on and immediately connects to computer or if possible, to the direct charger.
If it turned on, wait for while and then go iTune and restore.
If not, you can at least locate the local apple store and let them take look at it.
They might ask $ for repair but it shouldn't be so expensive.
you might try resetting your iPod (hold down SELECT+MENU for a few seconds) or restoring your iPod back to factory settings in iTunes just to make sure that it's not some type of software glitch?
hope this helps
Sep 24, 2012 | Apple iPod touch
My ipod touch is locked and i cant remember the code
Thanks for asking your question with Fixya Support. I will be glad to assist you.
Unfortunately if your iPod Touch is locked and you cannot recall the pass code to unlock it, you will have to perform a factory restore, in order to clear your iPod Touch of that previous pass code.
The good thing is, even though you will wipe all your current data on your iPod Touch, after the factory restore, you can restore your most current back up through iTunes to restore the data back to your iPod.
To restore your iPod Touch is simple:
* Be sure you restore your iPod Touch on the same computer or notebook that your previous iPod Touch backup files or stored.
* Now, make sure you are using the latest version of iTunes.
• Be sure your iPod Touch is correctly connected to computer or notebook .
• Finally, in the left column under DEVICES, click on your iPod Touch, then click on Restore under the Summary tab.
* Allow the process to complete and your iPod Touch will be restored to its original factory default settings.
* Now simply re-sync your iPod Touch with iTunes and this is where your last sync now comes into play. When you sync after the restore, iTunes will look for your iPod Touch's previous backup and per your permission, will restore your most recent backup to your device.
This time, when you set up your pass code... Make sure to write it down somewhere or in a place that is easily accessible and a in a place that you won't soon forget.
Thanks for contacting Fixya.
Regards,
- The MacTechTrainer
Nov 25, 2011 | Apple iPod touch
I forgot the password to my ipod touch
There is only one way, you must restore the ipod which wipes out everything if you forgot it.
Updating and Restoring iPod touch Software
You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch.
• If you update, the iPod touch software is updated. Your downloaded applications, settings, and data aren’t affected.
Note: In some cases, an update may also include restoring iPod touch.
• If you restore, the latest version of iPod touch software is reinstalled, settings are restored to their defaults, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. If you’ve backed up iPod touch with iTunes on your computer, you can restore data from the backup at the end of the restore process.
Deleted data is no longer accessible via the iPod touch user interface, but isn’t erased from your iPod touch. For information about erasing all content and settings, see “Resetting iPod touch” on page 122.
Update or restore iPod touch:
1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2 Connect iPod touch to your computer.
3 Select iPod touch in the iTunes sidebar and click the Summary tab.
4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available.
5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
For more information about updating and restoring iPod touch software, go
Feb 06, 2010 | Apple iPod touch
Want to reboot my ipod 16 gb touch
To reboot you ipod all you need to do is just turn it off and turn it back on.
If you mean restore your ipod follow these steps
Complete a Regular Restore
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the Internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch.
Complete an Advanced Restore
  1. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  2. Plug the iPod Touch into your computer.
  3. Power on the iPod Touch.
  4. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  5. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  6. Return to the above section and follow those steps to restore your iPod Touch.
Sep 24, 2009 | Apple iPod touch
Ipod touch turns on but tells me to connecct to itunes
You'll need to find a friend or family member that has a computer to resolve this issue. The iPod touch needs to be restored.
Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
Jun 24, 2009 | Apple iPod touch
Forgot my passcode
Jun 20, 2009 | Apple iPod touch
My ipod touch is locked and i forgot the passcode and its disabled and i cant link it up to itunes unless i unlock it which i cant
Updating and Restoring iPod touch Software You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch. ââ If you update, the iPod touch software is updated but your downloaded applications, settings, and songs are not affected. ââ If you restore, the latest version of iPod touch software is reinstalled, default settings are restored, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. In iTunes 7.7, you can also restore from a backup without deleting data stored on iPod touch. Note: Deleted data is no longer accessible via the iPod touch user interface, but is not permanently erased from your iPod touch until it is overwritten by new data. For information about permanently erasing all content and settings, see “Resetting iPod touch” on page 94. Update or restore iPod touch: 1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes. 2 Connect iPod touch to your computer. 3 Select iPod touch in the iTunes sidebar and click the Summary tab. 4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available. 5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
May 07, 2009 | Apple iPod touch
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
