Question about Epson Stylus C60 InkJet Printer
I refilled a black Epson C60 ink cartridge but the printer won't recognize it. I keep getting the message that there is no ink in the cartridge when, of course, there is. How do I get the bloody printer to print?!!!! Yes, I am very frustrated with Epson.
  • 28 Answers
Epson ink cartridges have to be reset after they are refilled with little device called a "resetter". You can purchase one for about $25 on the internet. You reset the cartridge by touching the resetter to the contacts on it. The cartridge is then considered full again. I have one of these somewhere in my office.
Posted on Mar 03, 2009
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
Epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Jun 26, 2011 | Office Equipment & Supplies
I have refilled my ink cartridges on my epson c60 printer and the printer display on the screen is still showing ink empty and the printer will not print
If you have refilled your cartridges and haven't re-set them, that's why they won't work. You have chips on both cartridges that need to be re-set every time you do a refill. You can either buy a re-setter on e-bay, or go to a refill shop to re-set them. What the re-setter does is assign a new serial number to the cartridge, thus "fooling" the printer to think you have popped in new cartridges. That is the only way to bypass the protection (chips) that Epson has put on their cartridges.
Sometimes, the message "low ink" or "no ink" appears even if the cartridges are not totally empty. If you are certain that their still is some ink int the tank, just re-set the cartridge without refilling it.
Apr 15, 2010 | Epson Stylus C60 InkJet Printer
My Epson NX415 does not recognize refilled and reset cartridges. What can I do about it?
Don't let your ink levels drop below 25% before refilling and resetting your cartridges. There is an inner and an outer chip on these cartridges. The inner chip disables the outer chip when it's contacts are no longer bathed in ink. So, it doesn't matter if you "reset" the outer chip after refilling your empty cartridge because the chip was disabled. I'm really curious how you refilled these cartridges yourself without souring yourself on refilling from the experience. I own a Cartridge World ink refilling store and I refilled a set of these cartridges when we had replacement chips available (we don't now because our chip distributor was violating Epson patents) and it was an absolute mess, took forever, and the cartridges still didn't work in our test printer.
Feb 13, 2010 | Epson Stylus NX400 InkJet Printer
I refill my epson C60 cartridges and have a chip resetter. Now, the cartridges won't release ink when printing. I get a blank page. The printer recognizes the cartridges. What is causing the blank page?
Put the ink cartridge onto a damp paper towel.
Does ink "bleed" onto the paper towel?
If not, then the print-heads are clogged,
and you should run the "head-cleaning" software (part of the software package for the Epson printer).
Dec 30, 2009 | Epson Stylus CX8300 Printer
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
Sep 04, 2009 | Epson Stylus C60 InkJet Printer
No ink
It appears the chip in your black cartridge shows the cartridge as empty. This may mean a faulty chip, or more likely that the cartridge has been refilled, but the chip has not been reset to "full". You must get a chip resetter - very cheap from E-Bay.
If you require further explanation of this, please post a new comment.
Mar 07, 2009 | Epson Stylus C60 InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
C60 says full cartridge is dry
You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
Change the cartridge when prompted.
Of course, having messed about with the jet, it may not work now !
Jun 05, 2008 | Epson Stylus C60 InkJet Printer
Error msg "installed ink cartridge cannot be recognized"
Take the cartridge out and put them back in, make sure that you will hear a click. If your going to have the same error, you need to contact Epson Technical Support. The cartridge might be defective. Here's they're number
United States Phone Nuber:
(562)276-7525
Hours: Mon.- Fri. spacer.gif 6AM-8PM (PT) Sat. spacer.gif 7AM-4PM (PT) Canada Phone Number:
(905)709-2567 Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT)
Feb 05, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus C60 InkJet Printer Logo
193 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
