Question about Moen Plumbing
Moen roman tub faucet on hot water side stops flowing and just trikles out
  • 374 Answers
If this occurs after you were able to get hot water to flow from the hot side then I suspect that it is a piece of debriis that has found its way to block the port opening. Remove the acess panel to the valve shut the water supply off to the tub valve using the handles only first on the valve. With the access panel removed tak e a bucket or other similar container and remove the hot water tubing from the spout. Once that is accomplished stick the tube into the container and turn the hot lever on. This should blow out any debris that may exist. Reassemble the valvle. If this did not work remove both the cold and hot feed tubes from the spout and use an air compressor to blow the spout out. If neither of these worked you will probably need to call a serviceman to resolve as other options require cutting the hot supply to the handle and may require special tools that you may not have handy. Thanks for using Fix Ya.
Posted on Mar 11, 2009
Water in tub is only hot for a few seconds and then turns lukewarm. We have hot water everywhere else.
Check this link: http://www.selfhelpandmore.com/plumbing/how-to-adjust-a-single-lever-shower-faucet.php
Nov 17, 2014 | Moen Kingsley Two Handle Roman Tub Faucet...
How to fix drip on Moen T951 faucet
Replace cartridge..Moen will give you free cartridges for life of faucet.
Sep 09, 2014 | Moen T951 Monticello Two-Handle Low Arc...
Set screw is stuck. Any suggestions on how to remove it to replace the roman tub faucet?
to replace the roman tub faucet you have to expose the faucet under the deck of the tub. Most of the time builders do not install a door to do repairs. So expose the underside of the deck of the tub, turn off the main water outside then cut the water pipe for the hot and cold water with a tube cutter. At this point take a sawall and place the blade so the side of the blade touches the bottom side of the deck.
and cut all the way though the body of the stem.
Do all three and your done with the hard part. Install your new faucet and enjoy.
Hope I was help to you Rich
Sep 05, 2011 | Moen T999/4999 Chateau Two Handle Roman...
I get hot water but no cold water from my moen one hand tub fixture.
pretty sure that model has shut-off's/stop's.they are on either side of the center of faucet,they take a slotted screw-driver.check that,and the balancing spool could be clogged,if the stop's are open check the cartridge real good,as well as the faucet body for any debris. if you end up pulling the cartridge flush out the valve body to prove flow from both hot,and cold.
Feb 18, 2010 | Moen 3175 Legend One Handle Shower Faucet...
I have no water coming from the HOT knob. COLD works fine. How do I access the water line under the tub, so I can turn on the HOT water supply to that knob. It's on a roman tub, but there is no access to...
Cut a hole in the sheetrock on the adjoining wall closest to the faucet and turn on the hot water supply. Then u will have to screw the piece of sheetrock back in and tape and spackle. then paint of course. My husband who is a plumber says there should ALWAYS be an access panel for a roman tub!!! if they didn't put one then u have to make one. u can buy one at a plumbing supply store to put in once u cut the whole. then u would have one for any future problems.
Jan 03, 2010 | Moen T999P/4999 Chateau Two Handle Roman...
I have a moen bathtub faucet with one handle. My problem is that when I rotate the handle to the hot side the water flow stops. How can i get hot water to flow?
you may have problem with your cartridge . you will have to pull it and take good look at it and look in the valve body to make sure no debri s is blocking the water port's
Dec 10, 2009 | Moen & One Handle Tub & Shower Faucet
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
No water flow
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
Apr 09, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen Castleby T6988 Roman Tub Faucet
with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
Feb 12, 2009 | Moen Castleby Two-Handle Widespread Roman...
Plumbing Logo
310 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
