Question about Smeg SE250XUK Stainless Steel Electric Single Oven
Electrical fault on SE250Xuk
My oven has a distinct smell like electrical wires are burning when it is switched on. The oven no longer is able to be switched off at the oven, but rather the electricity box. Is this major repairs?
  • 27 Answers
It may be something as simple as a crossed or frayed wire. This does not necessarily mean major repairs. Since it is electric, UNPLUG the oven from the wall. Then, take the burner rings out and lift the stove top. You should be able to lift it from the front edge, since it is hinged at the back.
Check the wires under the burner. If these wires are in good shape and the connections are solid, move the stove out from the wall. Remove the back sheet metal panel completely.
Once again, check the wires running the entire length. Make sure all wires running from the knob console to the rest of the oven are not frayed or missing the insulation coating and that the connections are complete and not loose.
If you find frays, some electrical tape should fix it just fine. Loose connections can usually be crimped with a pliers, or if it's a loose electrical connector type connection with a screw, you can remove the connector head and wrap bare wire around the screw, then tighten it down to secure.
If you find nothing wrong when you open it and inspect the wires, then it is possible it needs major repairs. If you are getting a burning smell from ANY electrical appliance, please leave it unplugged until you get it fixed. Nobody likes a house fire in the middle of the night.
Posted on Mar 03, 2009
Neff 1031 2
The heating element(s) may have shorted.
Apr 13, 2017 | Ovens
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
Jan 31, 2013 | Electrolux EW30EW65SS Stainless Steel...
My electric Oven keeps tripping the breaker off as well as making a popping noise while doing it and leaving a burning smell. When i turn the knobs to the burner on i hear a clicking noise coming from the...
Hi. YES you most definately have a short. The burning smell is coming from either the wire arcing and thus producing ozone and heat, or the insulation on the wire is being burnt. Take the back off the control unit to expose the wires and see if you can see where the wiring is burnt. It could be a loose connection, or something more serious.
If in doubt, call a professional repairman to check it out.
Earl Marshall
Norse Tool/Equipment Repairs
Sep 22, 2011 | GE JKP15 Electric Single Oven
My double electric wall oven smells like smoke, what can be the problem?
It depends o what kind of smoke. If it is just a burnt food smoke smell there is residue left on the walls that has refused to come off with cleaning and a harder detergent is required, perhaps allowed to soak for a longer time. If it is an electrical smoke smell, there is either a bad connection that is heating up and creating the smell or some wires hare carrying too great a load and are smouldering. Check the first item before looking at the next because that will require you to open the back of the oven to access the wires and contacts.
Mar 11, 2011 | GE Profile 30" Built-In Double Electric...
Oven not working but grill is please help
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
How to Video Tutorials on Domestic Appliances
Dec 12, 2010 | Smeg SE250XUK Stainless Steel Electric...
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Kenmore ultra self cleaning oven or top heat
I found that the 220 plug had burned out, that was where the smoke came from. The display worked because the ground "prong" was the only one burned. Had to replace the electrical 220 socked and the electrical plug on the oven.
Jan 13, 2009 | Ovens
Electrolux EOB5600 electrical fault?
goto home depot,lowes and get some ceramic wire nuts and heat tape and electrical tape.cut the wires back on both sides of the terminal block.bypass the t-block and connect the wires with the wire nuts wrap the heat tape then electrical tape on each one.if you have access to a amp meter take readings to make sure the amp draw isnt too high.i would think the wires just burned up from either a loose connection or the heat of the oven.this should solve your problem.
Jan 06, 2008 | Electrolux EOB5600 Ultrafan Electric...
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
225 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
