Question about Napoleon Auburn Pellet Stove Heater
I have a 1985 Whitfield pellet stove that has problems
I have a 1985 Whitfield pellet stove that has worked well until now. When the pellets drop, they do'nt catch fire right off...instead, they seem to smoulder for, gee, seems like more than a minute. Just not getting a good hot fire. Any imput folks? FrozeninMaine
Blockage/clean unit most likely
Posted on Jan 20, 2015
  • 56 Answers
Check the basics first fuel (supply and quality of) Air flow and ventilation. If nothing obvious google {whitfield pellet problem]. My guess is that something is plugged up.
Posted on Sep 14, 2009
I want a free wireing diagram 1992 whitfield pellet stove avantage--2
Request the wiring diagram from Whitfield.
Sep 21, 2017 | Home
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
When I light my pellet stove and push the start button the exhaust fan comes on but the smoke in the stove don't blow out the exhaust. What could be the problem?
Are you sure it is the exhaust fan and not the convection fan or the fresh air fan you hear? If it is the exhaust fan, check for blockage in the exhaust pipe.
Feb 22, 2016 | Whitfield Advantage II-T Service Manual
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Does anyone have any information on the Pine Ridge 500 wood stove? I'd like to know who the manufacturer is and what the EPA specs are.
PDF]installation and operation manual - Wood Pellet Stoves ...
www.pelletking.com/...stove-manuals/whitfield-advantage-iit-pellet-stove...
Services) and the listing mark is Warnock Hersey. Testing: In accordance ... The assembled pellet stove model Advantage II-T C FS and. Advantage II-T C INS ...
[PDF]INSTRUCTION MANUAL - Ignite Dealer Portal - Regency ...
manuals.regency-fire.com/getattachment/.../R12-R14-R16-Manual.aspx
Tested by Warnock Hersey ... LISTED FACTORY BUILT FIREPLACE ACCESSORY HEARTH STOVE ... it is important that you read this manual throughout.
Nov 01, 2015 | Home
I need to know where the high and low limit switches are located on a Winrich Dynasty pellet stove
The Low Limit Switch, goes in the combustion fan housing. The High Limit Switch, goes in behind the Room Blower.
Here's a repair site for you to check out, in more depth. Hope this helps! http://www.butkus.org/whitfield_operate/whitfield-pellet-stove-low-limit.htm
Nov 21, 2014 | Pool & Spa
I bought a house with a Warnock Hershey eclipse pellet stove. Am having some problems. Where can I find a manual?
Warnock Hersey is not actually a manufacturer's brand, but a certification. You can find more info here: http://www.wood-stove.org/firebelly-stoves.html .
or you could try this link:
http://www.pelletking.com/pellet-stove-manuals/Whitfield-Advantage-IIT-Pellet-Stove-Manual.pdf
I hope this helps you out & if it does please don't forget to rate me, kind regards, Paul
Sep 14, 2012 | Cars & Trucks
I just got a Whitfield Quest pellet stove from a friend. Do I need a fresh air pipe if I use it in my house/ basement? Also where can I get a repair/owners manual. Thanks Kurt Willem
Some people plump in fresh air but you can also punch out the fresh air in take out on the back of the stove and recirculate the air within your home.I would think twice about installing it in your basement . Basements have a tenancy to create a negative pressure, which means that it can become very difficult to create and up draft through the chimney , which causes the smoke to seep out of the stove into your home. The only way I have found to over come this is to run a torch in the stove for 5 mins before starting a fire, this creates an up draft which eliminates the problem.
Aug 19, 2009 | Napoleon Auburn Pellet Stove Heater
Napoleon Auburn Pellet Stove Heater Logo
974 people viewed this question
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Gene Haynes
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
