Question about Fisher and Paykel GWL11 Top Load Washer
Washer leaks from the bottom.
The hose that is leaking is aproximately 6" kinda shaped in a C. I can replace it if I can just get the part. The model is GWL11
    Scholar:
  • 89 Answers
Http://www.fisherpaykelparts.net/partmanuals/GWL11US.pdf
this web site has a parts break down. just find your part and order from your local repair shop
Posted on Mar 03, 2009
My GE washer leaks water during spin cycle only, seemingly from bottom of valve(?) where water hoses hook up, hoses look to be in good shape, only a year or so old.
If it is leaking at where the drain hose comes out of the wash machine, make sure the plastic spider clamp is seated securely in the groove on the drain hose. If that's not it, then, yes, you'll need to open up your washer to gain access to the inside of it. I don't know which model GE wash machine you have, but most of the GE top loaders can be opened by following the instructions in this youtube video:
Oct 19, 2014 | Washing Machines
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
I have water leaking from the middle bottom of washer, not leaking from hoses or water outlet
sounds like the water pump, pull the housing and look at the bottom center for a oval shape with two hoses.I bet you find the leak there.......GOOD LUCK
Nov 15, 2010 | Maytag SAV5710 Top Load Washer
I have a 2000 model Whirlpool washer and it is
Hello, the drain hose may have disconnected from the drain valve, these is the hose that leads up to the external drain hose and has that U shape in it.
Thanks
Jun 11, 2010 | Washing Machines
Leaking from the bottom of washer
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem that you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. If that happens, the entire outer tub would need replaced, but that might not be an economical repair to make and would require professional assistance. Hopefully, the main drain line is leaking and can be repaired. Sorry for your trouble and I hope this helped. Best wishes
Sep 13, 2009 | Washing Machines
Frigidaire front load Gallerry series washer model GLTF2070DS0
HI thanks for your question. repair clinic on line . part# or model # and they ship in 3 days good you can fix your self. thanks
Oct 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
198 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
