Question about Aiwa Car Audio & Video
Cd player gets extremly hot /sound goes in and out
Cd player gets extremely hot quick,sound doesnt come in the left door speakers only the right and skips on and off, the person who had the vehicle before me removed the rear door speakers and the dash speakers so all i have is some rockford fosgate components in the front doors could the lack of speakers be the problem? i have the cd player un hooked from the wire harness at the moment so it doesnt melt anything
simplemitch
  • 752 Answers
SOURCE: wireing harness
you can buy the proper harness for any vehicle at most stereo shops or even some at WalMart, but you have to hook it to the one that plugs into the radio. The colors on each harness will be identical- just match them up.
Posted on Dec 06, 2007
SOURCE: cqdf903u powering on but no sound in 2001 vw jetta
Puede que las bocinas sean amplificadas si es asi tienes que buscar un cable que trae el sistema del automovil para que funcionen si son las originales del carro
Posted on Mar 29, 2008
SOURCE: Chevy Tahoe radio wiring problems
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
Posted on Dec 02, 2008
  • 13 Answers
SOURCE: Trying to install a after market cd player into a
did u hook up the power amp wire
that truck does have factory amps
that wire needs to be hooked to the remote wire on the aftermarket radio
Posted on Jun 07, 2009
rteemon
  • 578 Answers
SOURCE: wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Posted on Jun 25, 2009
I need awireing diagram for a premiun sound (jbl) stereo with cd player for a 93 thunderbird
you should get a wiring harness to save you the trouble, however i just put in a kenwood in a 1997 thunderbird, if you cut the black wiring cover all the speaker wires are wrapped together and the other wires will be 12v constant acc, ground, etc. here is a diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire : Orange/Green
Left Front Speaker Negative Wire : Black/White
Right Front Speaker Positive Wire : White/Green
Right Front Speaker Negative Wire : Black/White
Car Audio Rear Speakers Size: 5x 7 speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire : Pink/Green
Left Rear Speaker Negative Wire : Pink/Blue
Right Rear Speaker Positive Wire : Pink/Blue
Right Rear Speaker Negative Wire : Green/Orange
Feb 03, 2013 | 1993 Ford Thunderbird
Onkyno receiver shuts off
The system is overheating
Jul 27, 2008 | Onkyo TX-SR605 Receiver
The door won't stay open when putting in a cd on my Technics SL-PG350
JUust get a different CD- Player ,It will cost you less then to have it repaired, WHere i live i can get a good used one for $10 to $30 at the most, End they are not hot,
Nov 25, 2012 | Technics SL-PG350 CD Player
Car audio issue
You should probably take out the stereo and check the cable connections. If it has been taken out recently and put back in wrong a wire might have been pinched blocking power going to speaker or the wire is shorting out.You might just even have a cable that got burned up somehow. Mike.
Sep 19, 2009 | 2004 Nissan Altima
Audio cuts out and back of cde-9872 is very hot
heat is a sign of transitors shorted. you can try to disconect each speaker to see if you have a short. also make shure u dont have low ohms. like multiple speakers to one chanel.
Sep 29, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
Acer aspire 5050 external speakers problem
Make sure that the speakers you are plugging in are powered.
Jan 11, 2008 | Acer Aspire 5050-3242 Notebook
Problem with boston acustics subwoffer
> check it in another computer
> if problems persist check setting of speaker also connectivity
Dec 02, 2007 | Boston Acoustics MicroMedia Computer...
Speaker Balance Trouble
Can you reset this unit to default settings?
Oct 05, 2007 | RCA RS2531 CD Shelf System
Possible Blown Speakers?
Any speaker, if abused, can be blown. And if overdriven with dirty power at extreme levels it is not uncommon to burn out the voice coil. You might also want to check out the speaker surrounds. If they go, the speaker works but sounds lousy.
Localize the problem by hooking up two known good working speakers and see what happens. If they also do not work properly or sound like cr-p then the radio is at issue.
Jul 24, 2017 | JBL - MR4W Am/Fm with CD Player White
Car Audio & Video Logo
85 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
fordexpert
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
