Question about Casablanca Fan Stealth 3211T Ceiling
Wiring for ceiling fan - Casablanca Fan Stealth 3211T Ceiling
  • 27 Answers
Since ceiling fans can be wired a number of ways, typing all directions would be tedious and diagrams are better anyway, try this link.
If that's no help to ya, just repost on this problem and I'll follow up with more help.
Posted on Mar 03, 2009
Ceiling fan and light not working after short trip.looking for wall switch,gfi,or breaker.no wire ring diagram
Ceiling fan and light Bruce, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Wire Fan Light With Black White Blue Wires
Install or Replace Ceiling Fan
Wiring Diagrams Ceiling Fan and Light Kit
How to Wire Ceiling Fan With Light With Different Switches Ceiling Fan...
Mar 23, 2016 | Dryers
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
I am installing a ceiling fan/light with a remote control and the wiring in the ceiling has a red wire and two white wires which are connected. I am used to seeing only a black and a white wire. in order...
the two white wires are the neutrals, just add the fan's white wire to the other whites. The red wire is the hot wire, same as a black, so connect it to the black.
Oct 11, 2009 | Home Decorators Collection Star-tech Fan...
Does the blue wires connect to the black or white wires? I cannot find the instruction booklet. Thanks
Hi, At the fan you'll have a black wire, blue wire, green wire and white wire.
In the ceiling you'll have a black wire, a white wire, and a bare copper wire. If you are using the same wall switch to turn on all of the power to the fan AND the light, connect as follows:
White at ceiling to white from fan
Black at ceiling to black and blue together from fan.
Bare copper wire at ceiling to green wire from fan.
When connected like this, the main power is from the switch, and the fan and light may be set by the pull switches on the fan.
Best regards, --W/D-- Please feel free to rate this solution... thanx!
Aug 03, 2009 | Casa Vieja Endeavor Cherry Ceiling Fan
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
Ceiling Fan Electric
hi,
you may have two dedicated ceiling fan circuits coming out of that box, check to make sure theres not a black wire bunched up in the ceiling or cut off, or try this
1.white to white wires, and black wire and black with a white stripe to red wire out of ceiling for fan and light together operation
2. If you can find the black and the red and the white coming out of the ceiling then you may have two switches on the wall for that fan, red for black fan wire, black with white stripe for the to black out of the ceiling , white all together. try that combination
for separate light and fan control from the wall
good luck, and be careful
J
Aug 06, 2008 | Hunter 22451 The Brookline Brushed Nickel...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Ceiling fan
OK, the wires coming from the top of the fan are going to go into the junction box in your ceiling. Out of the ceiling, you should have a white wire, a black wire, and a green or bare copper ground wire. Make sure your power is off at the fan. Your wires coming out of the fan should be white, black, blue, and a green ground wire. Pull the wires through the top of your fan, and connect the white to the white in the ceiling, the black and blue wires from the fan to the black wire in the ceiling, and then connect your ground wires together. Make sure you use wire nuts and twist them firmly onto the ends of the wires. If you happen to have a red wire coming out of the ceiling as well, just put a wire nut on it and stuff it back into the ceiling box. The blue wire is what works your light kit, and the black is for the fan. Hope this helps you!
Jan 05, 2008 | Casablanca Fan 3245T Ceiling
Casablanca Fan Stealth 3211T Ceiling Logo
508 people viewed this question
Top Casablanca Fan Dryers Experts
 Jack Jr
Jack Jr
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
