Question about Fisher and Paykel GWL11 Top Load Washer
Need replacement hose
This piece is aproximately 6" curved aroung in a c shape sort of..
  • 145 Answers
Hi welcome to FixYa!
I know exactly what part you need- you can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=226&category_id=55
Posted on Mar 03, 2009
Unlock code for an blackberry 8520
There are two methods for unlocking Blackberry8520 by MEP number and by IMEI#.
The simplest method for unlocking by IMEI#.
You can find your Blackberry 8520 IMEI number by follow one of these steps.
1.By Pressing *#06# into the phone.
2.On your Blackberry cell phone, go to Options-->Status.
3.put the battery out,there should be a white sticker it will show your Blackberry IMEI #.
This Blackberry Unlocking codes provider provides unlock code for Blackberry 8520.
Hope this helps.
Jun 27, 2010 | RIM BlackBerry Curve 8520 Smartphone
Plastic t hose connector cracked,what do i ask for at part store , lost broken part, this has three hoses connected to it, and it goes to the heater
If all the vacum hoses are the same size, cut a piece about a 1/4"off 1 of the hoses, and take it with you to
the parts store. Give the piece of hose to the parts guy/gal and tell them you need a 3 way vacum connector. Some are T shaped some are Y shaped get both they're cheap. Use the one that fits best without kinking the line. Also if you have different size
hose to the connecter, cut a 1/4" off each.
Hope this helps. Good luck
Jan 26, 2010 | 1994 Cadillac DeVille
Picture is a mess words look like looking through a coke a bottle bottom, with a curve to the whole picture colors are seperating
This is a convergence issue this will need to be repaired its is common with age and can be repaired you looking aroung $50 bucks to have this done Tv needs to be opened up there is little pieces of magnet type substance that helps with convergence on the back of the tube this will need to be evaled and replaced.
Thanks and please leave postive ratings and feedback for your free answer today!
Nov 19, 2009 | Office Equipment & Supplies
I want to make a sling shot
Hello, the slings that were used in those days were rather crudely made weapons. The sling itsself was usually eye shaped to hold the rocks that were being thrown, it was made of leather. The two chord on each side were made of twisted leather aproximately three feet long. You need to make two holes at each end of the sling. you fold one corner over to meet the opposing hole and you then tie the first piece of leather thong to it. Repeat the procedure for the opposite side and you have a working slingshot sling. I hope this helps.
Nov 02, 2009 | Avenger Toys
Lower section of upper radiator hose seperated from filler cap ho
yes, you are right! do this! the thermo costs between 3-6 dollars9100f2e.gif
Apr 26, 2009 | 2000 Dodge Durango
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Washer leaks from the bottom.
http://www.fisherpaykelparts.net/partmanuals/GWL11US.pdf
this web site has a parts break down. just find your part and order from your local repair shop
Mar 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
My cuisinart coffee maker leaks
1. Purchase (1) a couple of feet of 3/8" ID by 5/8" OD temperature resistant silicone tubing from a beer/wine-making supplier, or online through Ebay, and (2) a couple of hose clamps big enough for the tubing.
2. Unplug the coffee maker and turn it upside down on some old newspaper.
3. Using a T10 Torx screwdriver, remove the 4 screws that attach the the bottom plate of the coffee-maker, and remove the bottom plate.
4. Unclamp the two orange/red hoses from the C-shaped heater, and carefully pull/remove the other end of the two hoses. One hose is a water intake hose from the water tank to a C-shaped heater element, while the other hose is water outlet hose that goes from the C-shaped heater element to the sprinkler assembly.
5. Carefully remove the small plastic stop check valve from the water inlet hose end close to the C-shaped metal water heater; and take care to not drop/lose the little round plastic ball inside the plastic stop/check valve, while noting which way the stop-check valve is oriented in the hose.
6. Cut two pieces of your food-grade / temperature resistant silicone tubing that are the same length as the old hoses.
7. After reinstalling the stop-check valve in the new inlet hose/tubing, reinstall the two sections of hose/tubing, and use two hose clamps to attach the new tubing to the C-shaped water heater.
N.B. Remember that the stop check valve s/b oriented such that hot water in the C-shaped heater element can't go back to the water tank.
7. The ends of the hose that attach to the C-shaped metal water heater s/b clamped, while the other ends just push onto the water tank and sprinkler assembly with a with a little pushing and twisting.
See http://www.cocosvariety.com/2011/11/fixing-cuisinart-coffee-maker-alternate.html , as that is the original information source for this posting and the image below. i.e. Credit goes to Coco's Variety !.
Also, in the image below, the hose on the left is the water inlet hose, while the hose on the right is the water outlet hose.
Dec 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Admrial dishwasher
not really all that familliar with the admiroal d/w, but ther eshould be some sort of float switch/ overfill switch inside the tub assembly. usually a mushroom shaped plastic cap in either of the front corners under the lower rack. if that "switch" is stuck in the up positon , the machine would not allow any water to flow intoo the machine, sometimes a piece of pasta, or a utensil willget stuck under it not allowing it to "float" freely. you can start there!
Nov 29, 2008 | Dishwashers
Broken fitting
You don't have to change that piece,just tie the hose (drain hose ) to something that is equal height,this prevents siphoning.
Please Rate This !
Jul 15, 2008 | Danby 22 in. DDW396 Free-standing...
Fisher and Paykel GWL11 Top Load Washer Logo
27 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
