Question about AMD MicroStar KT3 Ultra Socket A ATX Motherboard - MS-6380E
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but that did not solve the problem the symtom remain the same. I need to get a manual for this mother board so I can trace and verify all connections are good. Can you help with this problem and where I can download the manual.
  • verb492 Apr 16, 2009
    Bought new motherboard a couple of years back. Moved to new city and lost manual in move. Now ready to use MB but don't know where jumpers go. Where can I get a manual for this MB? KT3 Ultra 2 CE MS-6380E Ver 1.0
2 Suggested Answers
  • 11 Answers
SOURCE: Is my KT3 Ultra CE
It is a standard ATX
Posted on May 05, 2011
Motherboard turns on but computer can not se almost everthing
Hello there!
Hopefully, I'll be able to help you troubleshoot your problem..
I "poked around" for a spec-sheet on your motherboard:
http://www.legendmicro.com/store/2940_MSI-MS-6380E-010-KT3-Ultra-Socket-A-Socket-462-for-AMD-Athlon-XPDuron-Processor.lmsp
As you're probably aware, this is (in computer years) an antique, but still workable, assuming all cables are in good shape, and tightly connected. -- Again assuming all the cables are good and properly connected, the FIRST THING to try is to replace the bios battery, as it is quite an old motherboard.. considering the age, it is very likely that the battery (if original to the board) is dead, and unable to hold a charge. Motherboard batteries are cheap, easy to find and fairly universal. Try picking up a couple at your local electronics store / dept.. bring the battery along with you for reference.
After you've changed out the battery, make sure you do a bios reset on the board. Find the jumper on the motherboard (mobo for short). with the board properly connected to a power supply, and all needed computer components, take note of what position the jumper is in. With the board / computer being powered down, and the power supply (PSU for short) being unplugged from the wall, move the jumper to the opposite position. Wait about 10-15 seconds. Plug the PSU back in. Wait another 10-15 seconds. Unplug the PSU again, and put the jumper back into its original position.
Then plug the PSU back in, and try to power up the computer. If the problem still exists, unplug the PSU. Ensure that the RAM "sticks" AND the CPU are properly seated in their respective slots / socket.
Then again plug the PSU power cord back in. Try to power up the computer. Assuming that the mobo hasn't failed due to its old age, the computer SHOULD correctly "fire up", and you should be good to go. Feel free to contact me with any further questions!
Jan 15, 2014 | AMD MicroStar KT3 Ultra Socket A ATX...
Keepalive battery failed how do I get BIOS to work again
If the battery on the motherboard dies, the date and time might not be remembered, but the BIOS should at least have default settings.. Have you pressed the "Del" key during Startup to change BIOS settings? This is a copy of the manual for that mb..
Start on page 51 to see how to enter the BIOS and make changes. There are some explanations of different settings.
http://www.manualslib.com/manual/360284/Msi-Kt3-Ultra.html?page=51#manual
Nov 17, 2013 | AMD MicroStar KT3 Ultra Socket A ATX...
Can MSI MS-6380E support radeon x1800?
1) Motherboard uses a Socket A processor socket. Also known as Socket 462.
http://en.wikipedia.org/wiki/Socket_A
When they switched from the Athlon single-core processors, to the Athlon 64-bit dual-core processors, they went to a completely different processor socket.
AM2,
http://en.wikipedia.org/wiki/Socket_AM2
So using the MSI MS-6380E motherboard with a dual core AMD processor = NO.
I don't seem to find an AMD Athlon 64 X2 1.8GigaHertz processor, except for a mobile version. One used for a laptop in otherwords,
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113047
Uses a Socket S1 mobile processor socket,
http://en.wikipedia.org/wiki/Socket_S1
List of AMD Athlon 64 microprocessors,
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors
Pretend like I'm from Missouri, and Show Me.
Find the processor by it's AMD part number, and post the URL of the website in a Comment.
http://www.amazon.com/AMD-Athlon-Venice-Single-Core-Processor/dp/B003RXLMCC
AMD Athlon 64 3000+
SINGLE-core processor, not X2.
(Socket 939 processor socket, too)
Show me the Processor, and then we can go on.
Regards,
joecoolvette
Sep 11, 2012 | MSI Computers & Internet
I just bought a msi kt3 ultra ce computer with no drives. What drives do I need to get it running?
If you are looking for the motherboard device drivers then -
You can download the device drivers from MSI WEB supportsite, select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
Sep 09, 2011 | MSI MS-6380E (MS-6380E-010) Motherboard
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but...
Sounds like the board or processor has failed. You will have checked all the power connectors to the board? Usual fix is a new board, rather than trying to find which component on the board has failed.
manual
MSI MS 6380LE User Manual
specs
MSI KT3 Ultra2 Specs
MSI website details on the board
KT3 Ultra Ultra ARU Motherboard The world leader in motherboard design MSI...
Seems to be a problem board
Questions Answers for kt3 ultra ce ms 6380e
Jul 12, 2017 | AMD MicroStar KT3 Ultra Socket A ATX...
I NEED MSI KT3 Ultra CE Motherboard MANUAL OF INSTALLATION
the manual is available for download here. http://www.msi.com/index.php?func=searchresult&keywords=MS-6380E&table=download
make sure you have adobe free reader installed so you can view it..
Regards..
Apr 27, 2009 | MSI MS-6380E (MS-6380E-010) Motherboard
Need help on connecting up motherboard to rest of pc
I downloaded the PDF Motherboard Manual for the MSI MS-6380E Version 1.0, just now.
Let's take a look at that JFP1 header.
This view is looking at the JFP1 header, sitting at the bottom right of the motherboard, TO THE LEFT of the JFP2 header. The JFP2 header is at the very bottom right hand corner. The JFP1 header is just to the left of it. The processor is to the Top/Middle.
Looking at the pins going across the top of the JFP1 header, they are as follows,
2, 4, 6, 8, and there is no 10. There is no pin for 10.
Looking at the pins going across the bottom, they are as follows,
1, 3, 5, 7, and 9.
Pins 6 & 8 are for the Power On switch.
Pins 2 & 4 are for the Power On light, (LED light)
Pins 1 & 3 are for the HarDDrive activity light.
Pins 5 & 7 are used for a Reset switch. (IF, you have one)
Should you not have the Motherboard Manual, go here,
http://motherboards.org/mobot/manuals/MSI/MS-6380E/
(If this doesn't come up as a link, copy and paste it into your address bar, then press the Enter key)
On this page click on ->Download <- to the right of
File: 6380ev1.0.exe Version: - - Release Date: - -
When you do a small window will come up. Click on the empty circle to the left of -> Save.
This file will be saved either directly to your deswktop screen, or your My Documents folder. I don't know how you have your downloads set up to be saved. I save them to my My Documents folder.
Once you see this file, double-click on it. It's a WinRar file. There will be a Microsoft 'Squawk Box' that comes up. "Warning this publisher could not be verified, ya-da, ya-da"
Ignore it! Click on -> Run
Now the WinRAR extraction archive will come up.
Click on Run.
Now go to the PDF file and double-click on it.
There's your Motherboard Manual.
Apr 12, 2009 | MSI KT3 Ultra Motherboard
Computers & Internet Logo
1,464 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
