Question about Canon MP610 Photo All-In-One Printer
Printer cant print in black and white
Ok there was a paper jam, and ever since then if i print a black and white text doc it comes out multicolored and mising bits of print here and there
This happend to me also and I finally found out that the printer uses collor cartidges for GRAY printing. The back cartridge is used for BLACK printing ONLY. So if the printer was short of one collor in my case it was magenta (red) the gray parts of BW prints started to be green!!! When I put new magenta cartridge to the printer gray was gray again...
Posted on Mar 07, 2009
Error Code
the pw sensor on the cr assy is dirty.clean it.
move the printhead with your hand and place it to the right end and turn the printer on....
maybe will work...
Apr 29, 2014 | Epson Office Equipment & Supplies
I want to print in white ink on black paper. According to our local help desk this is not possible. I have a Canon MX310 printer. Wayne
The help desk is right but there is a way around this problem.
This printer is a color printer. The only way to print white text on black is to a program such as PowerPoint and create a black colored page and then use white colored text. You need to put white paper in your printer.
This will cause the printer to use a very large amount of black ink and if the paper is too porous then the printed text will not be clear. Make sure you use inkjet paper.
Dec 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Cant print text but prints headers, footers and pictures
try to make a copy ...if success
try to disconnect the power cable from the back of the printer and reconnect it after 20 seconds
try to print from the notepad ...............if success great
or else
uninstall the printer from the computer and reinstall the printer as a fresh
it should work and it has worked in most of the issues ................. thank you
HAMID
Oct 20, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hp j4680 says "paper jam"
Try this. Sometimes you get that message because a previous jam was never fully fixed.
Sep 29, 2009 | HP J4680 Office Jet All-In-One Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Getting a 5100 printer error
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 08, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Paper is coming out all black
The most likely cause is a faulty toner cartridge, replace it
Jun 10, 2008 | HP LaserJet 2420 Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Test print great, document printing blurred
Have you tried a new cartridge yet? I know it doesn't make sense at first but I suspect the cartridge has a problem and your test print isn't exercising the printer like the Word doc is. If the new cartridge works than the problem is probably poor quality ink, the hole you used to refill isn't sealed correctly or the cartridge or jets were damaged in some way.
Sep 02, 2006 | HP DeskJet 3325 InkJet Printer
Canon MP610 Photo All-In-One Printer Logo
115 people viewed this question
old marine
old marine
