Question about Sony Walkman NWZ-B103F MP3 Player
Player not starting
My walkman is not starting. even battery is full. it will on a a little bit shows walkman in disply then it will turn off. what may be the problem. any software i need to install????.. thank you my walkman is not starting. even battery is full. it will on a a little bit shows walkman in disply then it will turn off. what may be the problem. any software i need to install????.. thank you
    Problem Solver:
  • 5 Answers
Buggy firmware. Reset the player using the small button on the device
Posted on Apr 22, 2009
I have charged the player for the first time, when the battery was full I tried to turn it on....The display shows HOLD and then immediately the screen shows POWER OFF....Cannot turn this on ...
turn the hold switch off at the side if its still doing it then re set it switch the hold to on then of and hold down the menu button untill it re starts
best of luck
merry christmas
Dec 22, 2010 | Sony Walkman NWZ-B142 MP3 Player
My walkman wont turn on
Not sure if it's the same problem as mine! My battery was ran completly flat and then wouldn't turn on even after being plugged into the computer and hours of it juset sayin 'connecting'. I looked on Sony's website and found this -
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
  1. Battery must not be discharged 100%
  2. If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
I bought a usb adapter charger plugged it in and its back to normal!
Jul 28, 2010 | Sony Walkman NWZ-A828 Digital Media Player
My walkman mp3 just hangs when i press the play button. showing just walkman
that used to happen with my old SNW.... the way i fixed it was updating the firmware. you need your computer connect cable, the sony website, some hard drive space, and a little bit of patience. i recomend making a backup of everything on the usb device before starting this prossess, just as a precaution.
step 1 (optional)
backup your stuff
step 2
go here:http://esupport.sony.com/US/perl/swu-list.pl?mdl=NWZ-B135F&region_id=1
step 3
follow the procedures included.
Apr 11, 2010 | Sony Walkman NWZ-B135 MP3 Player
White screen on my phone
Its WSOD (White Screen of Death)
The Most Common Problem for SE-Walkman Phones.
There are tested/working ways to work it out.
You have to flash your Firmware, BUT read the full procedure first and ask me if you got any problem, before proceeding.
The Tutorial goes here
Note: This solution will ONLY work if your Phone shows a pulse of vibration when turned on.
Regards, Waqar.
Sep 23, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Won't send messages
disply show is dead tell me and mail me sameer_mishra1@yahoo.com
Aug 25, 2009 | Samsung Gravity SGH-T459 Cell Phone
Fully charge sony walkman NWZ-E436F does not turn on power at all
well u might have gone wrong u should charge ur walkman for abt 3 hrs first use untill full appears and it is recommended that even if u dont plan to use u r walkman u should atlest charge the battery once a while for battery mentainance try to reset ur update the player firmware.or even then if it dont comes send it to sony or have a converstion with sony support
Jan 31, 2009 | Sony Walkman NWZ-S616F MP3 Player
Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Jan 02, 2009 | Audio Players & Recorders
Player not starting
Oct 29, 2008 | Sony Walkman NWZ-B103F MP3 Player
Sony Net MD Walkman (MZ-N910)
had the same problem a few minutes ago!
removed the battery but it didn't help.
tried with another md, no success
tried the same md in another Mz 910, no success
then it got on my nerves and I gave the MZ n910 a little shock with my hand.
It worked, stopped spinning and started to play.
It was, I think, a spinning problem, md couldn't play properly, the little shock helped.
Apr 09, 2007 | Sony Net MD Walkman MZ-N910 Portable...
Sony Walkman NWZ-B103F MP3 Player Logo
447 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
